Question about HTC Radio Communications
Suddenly I found permanent wired headset Icon on the screen of my Touch 3G phone, which does not let me use my phone and hearing voices and any other sounds. It still exist even after hard reset. so that I cant use my phone without headset. I have to have it always plugged to use my cellphone.
SOURCE:
  • 490 Answers
SOURCE: 6020 headset
u need to plug in headfones then do restore of ur handset...reinsert sim and it will be done....
Posted on Oct 15, 2007
AvioriX
  • 689 Answers
SOURCE: Phone is Locked on headset setting even though there is no headset connected
best thing to connect a headset and take it out, that will trigger the function that it will come back to handset.
Good Luck
Posted on Mar 22, 2008
SOURCE: My Ps3 Headset -- LOGITECH
This sort of happened to mine, but i just switched my headset output to the default, so it comes out my telly instead of the ear piece...
Hope this helps
Posted on May 27, 2008
  • 21 Answers
SOURCE: HOW TO REMOVE HEADSET ICON IN MY NOKIA N70
maybe you had your phone wet on the bottom part where the headset is to be plugged in. bring it to the nearest repair shop for the just to clean the metal contacts then, your icon will be gone
Posted on Feb 26, 2009
TimeDefensiv
  • 746 Answers
SOURCE: don't have speech recognition tab in control panel-speech
Go to control panel click on sounds audio dvices then tab on voice and click on test hardware then click on next now there are two options one is recorder and second is playback. Now click again on next when you click on next both volume should be enable then click on next and then finish. Now 100% guaranteed it will work and you can voice chat now. Cheers!
Posted on Aug 01, 2009
Ok I have a moto G cell phone and I have a moto H300 bluetooth.. All I need to know is what voice commands do I use to work it
Darr-
You have to touch your phone or your headset to initiate voice search/commands. The Moto G doesn't have a voice search function enabled all the time that allows you to activate it completely with your voice via headset.
Mark
Motorola Headset
Feb 16, 2015 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Plantronics Explorer 320 I can hear but nobody can hear me
ok..try to go your sound settings, maybe the microphone is turned off. OR try to restart your phone just to make that headset is working properly.
Jan 22, 2008 | Plantronics Explorer 320 Wireless Headset
Since this morning, when making a phonecall, others are unable to hear me and I am able to hear them. I have the IPhone 3g. Is this a known problem? What can I do? I'd appreciate any help.
I have about 65 iPhones in my organization that I manage. I have had a few of them have this problem. It seems that the microphone at the bottom of the phone goes out/goes bad. Usually the sound through a bluetooth headset or the/a wired headset still works. The only permanent solution is to replace the phone. If you are eligible for an upgrade, I hear that the 3GS's are going down to $49 from $99 this month.
Hope this helps.
Jan 11, 2011 | Apple iPhone 3G
The headset icon always appear in my nokia n70 and cannot remove and when i connect my headset ... It doesn't work . With or without headset the headset icon always appear in my screen . during incoming...
what you will do,you will press*#7780# then it will want your password,then you will put your password and wait few minuts,if your ph take restart automaticaly, then ok, other wise you will restart your ph manualy
Jul 11, 2010 | Cell Phones
Noise problem from mic when I use my touch 3g phone
Probably this problem caused by microphone in your handset so you should replace it
Apr 13, 2010 | HTC TMobile myTouch 3G Wristlet (Purple)
Souckt of headset doesn't work
Nokia uses a different type of connector configuration.
You must use a headset that is makde for Nokia only.
Also, a Nokia headset will not work with any other cellphone brand..
===sorry=====
Sep 15, 2009 | Nokia 6630 Cellular Phone
The headset icon always appear in my nokia n70 and cannot remove and when i connect my headset ... it doesn't work . with or without headset the headset icon always appear in my screen . During incoming...
Feb 25, 2009 | Nokia N70 Cellular Phone
Radio Communications Logo
Top HTC Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a HTC Radio Communication Expert? Answer questions, earn points and help others
