MY KINGSTON DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO HAVE A WRITE PROTECT DISK
i don't know
Hi my flash disk is inficted with 4 viruse , my flash disk write protected and i'cant remove the viruse or Format the flash disk !! so i'm very unhappen !!! do you help me in this problem ?
Http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
This is NOT any type of viral executable, nor a joke. I tried it on my "trash PC" first, and after it worked, I decided it was safe. I scanned it for viruses, and it checks out ok. I personally testify for this small zip file. I encourage everyone every where to spread the word about it.
http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
Thanks,
CRneXt
I cannot find "StorageDevicePolicies" in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies on my computer.
Any idea for that? Help, pls!
Thanks in advance!
Please check if there is any lock in your data traveler which is stopping you to format it.....but if you dont have any lock in your data traveler you can solve your problem through registry ....you have to make some changes into your windows registry in order to format your data traveler.....
1.
Check out if the USB drive has a small swich for write protection.
2.
Windows can write protect USB drives too. Check out the registry under
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0'.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
click start click to open on my computer you should see your Hard drive C: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Hard Drive (It should be C:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right click on your usb drive select format
hope this helps you
Thank's guru
dilipbagdi
you are genius
thank you very much you have solved my problem
GA ada yg BENERR
HOLY ****, DILIPBAGDI !!!!!
i have been having an issue with this for about a month now... and have been sparatically searching the internet for a solution and you just saved my life !
Thanks.
First, check if the card is inserted properly to the slot... push it firmly so that all nodes touches the inside of the card reader..
my pen drive is write protected... it is not formating... so please provide the solution...
write protrcted
i have my audio mp3 player but i cant format it
[email protected] ANSWER ON THIS
HOW TO FORMAT A WRITE PROTECT USB DRIVE
my ipod classic(80GB) currently got a problem later on i connected it to my pc and the file system was now RAW i tried formatting it to fat32 as apple support recommended that for it but it says media write error.Also when i used itunes to restore it,it tells me that there was an error on a sector (1439).I think i have a problem with my sectors and I think they are corrupted
download
pagel ke potero solution nahi jantt to kis liy web bnai hai
