Hotpoint Ultima WF860 Front Load Washer Logo
Monica Weston Posted on Apr 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wf860 door seal
How I do I remove and replace door seal with a new one
Thanks
peter gittos
Level 2:
Novelist:
  • Expert 247 Answers
  • Posted on May 08, 2008
peter gittos
Expert
Level 2:
Novelist:
Answers
247
Questions
Helped
118051
Points
408
Un-plug the washer take the lid off now open the door undue the clasp that goes around the rim of the door seal on the outside of the washer (look carefully) once done the door seal should push into the washer now if u look into the washer from the top at the front though u will see a another clasp going around the door seal on the inside of the washer this is a screw un-screw it once done then the door seal should pull out repeat backwards to replace it m8
1helpful
How do I replace bottom door seal on Fisher and Paykel dishwasher DW60CC/CE
  1. Open the dishwasher door and remove any debris or old pieces of the seal from the door and the dishwasher.
  2. Clean the area thoroughly to ensure the new seal will adhere properly.
  3. Take the new seal and carefully line it up with the door, making sure it fits into the channel around the edge of the door.
  4. Start at one end of the door and work your way around, pressing the new seal into place and making sure it's seated firmly.
  5. Once you've finished installing the new seal, close the door and inspect it to make sure there are no gaps or misaligned sections.
  6. You do not need to use sealant or glue for the replacement of the bottom door seal.
1helpful
2answers
Hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
2answers
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
15helpful
3answers
How to replace door seal of Hotpoint WF860 washing machine
Hi, This is a very simple and straight forward job. First turn off the washing machine and remove the plug from the wall and earth the plug on the cabinet of the machine to remove any residule current in the machine. Remove the top of the machine with the screws at the rear of the machine. You can now look in the top? Open the door and take off outer door seal clip ( look and you will see how ) If it is a plastic clip it will have a small cut out in the side for a small screwdriver to be put in a pushed open. It could even be a small spring that is laying in side the small lip of the door seal. You could now attempt the removal of the door seal if you can see the inner clamp to get a long screwdriver onto the screw! If not now remove the soap drawer. Remove screws from around the soap drawer and slide the facia to the right and it should all be off.. Then you can remove the three screws that hold the front on along the top and the same along the bottom edge of the front panel. This then will allow you to take off the front panel and have better access to the door seal. Then once you have replaced the door seal you just need to replace as you took off..
Good luck................
Slight leak
It dpends. see if you can see any staining on front of cabinet under the door , if you can then yes it will mean new seal.
Another source of water could be water from the dispenser trickling down the front of the m/c.
Another possibility is that you have a leak from under the front of the washer. Put a piece of newspaper under the front of the washer, this should enable you to pinpoint the source of the leak.
Hope this helps
Please leave feed back
1helpful
I need to replace a door seal, Hotpoint Ultima WF860
Push the top cover to the rear and lift at the same time, then ease the control panel to the right, you will not get control panel off with the top cover in place.
This will then give you access to the front panel scews, located at the top and bottom of the panel. remove the door seal ,and door lock, then lift the front panel away.
1helpful
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
4helpful
How do i change the door seal on hotpoint ultima wf860
hi this is a ten minute job take your lid off your machine and then take you soap drawer out there are 2 screws in the behind the soap drawer undo these unclip the top board as you look in side the machine and put the fasia in a safe place now you will have two screws on the top of machine from where you just took the facia off and 2 underneath the bottom by removing the plastic kicker plate undo these and open the door to the right you will see 2 screws that hold the interlock in remove these and then remove the band around the door seal normally metal with spring now lift the front of the machine upwards and that will be the front off now unclip the door seal from inside and check for holes if ok soak in bleach over night and rinse in the morning try some descaler to remove and limescale when you use machine again total 10 screws to undo really easy goodluck and please leave feedback
How do I replace the door seal on a Hotpoint WF860
unless you are really bored don't try it ..front side not bad but inside where it mounts onto outer tub can be a big black bear ..little space to work and rear band even tougher
2answers
Water leaking from front
tear in the door seal, will probably need new seal - had this a few times, apparently usually caused pulling large loads out in a clump pulls and tears at the seal
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
