Sharp AL-840 Laser Printer Logo
Posted on Oct 22, 2017
Can't get al-840 to print anything!
I finally found the right driver for my Sharp AL-840 to be compatible with my Windows XP, but now nothing will print. The copier copies, I just can't print from documents or the web. Protonic.com said I need a new printer or a new parallel cable. The cable is new. I just bought this unit. I can't afford to buy another one! Can you help?
4 Related Answers
Anonymous
  • 48 Answers
  • Posted on Oct 08, 2008
SOURCE: Driver for Sharp AL-840 Laser Printer
This site provides you access to the driver you require
-you will need to know your operating system (XP or 2000, etc)
http://www.driversdown.com/drivers/14637.shtml
hope this helps
Anonymous
  • 60 Answers
  • Posted on Feb 27, 2009
SOURCE: Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
A
Anonymous
  • Posted on Mar 26, 2009
SOURCE: Need Vista driver for Sharp AL-840 printer/scanner
Not available.....XP only
Anonymous
  • 95 Answers
  • Posted on Jan 15, 2010
SOURCE: Displaying L and 6 (flashing) on Sharp AL-1000 copier
The L-6 indicates there is a problem with the "polygon motor". This is the motor inside the laser unit. The laser is not servicable unless it is opened in a "clean room" (no dust particles). If turning the copier off and on does not resolve the issue then the laser needs to be replaced. You could try taking off the back cover of the copier and unplugging and re-connecting any wires you can see connected to any board. sometimes it may just be a wire has worked its way loose.
Cant find the driver for my AL 1642 cs for windows 7
It can`t print with 7,apply win xp and install it.
2helpful
2answers
I want to install my AL-1530CS with my new HP Laptop 64-bit running Windows 7. Where do I get the correct driver?
There are NO Win 7 drivers, and I suspect there never will be. Sharp are NOT writing a Win 7 driver, for this "Old", according to Win 7, hardware. You may be able to install a, XP SP2 or Vista 64 bit driver, and setup in Compatibility Mode, however if you do,do this EVERY-TIME you Bootup you MUST press F8, and select to Disable "Digital Signature Checking" at bottom of list. You need to do that at install time too.
5helpful
2answers
Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
http://www.sumthai.com/s0104/index.php?tpid=0086&pageno=1
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
1helpful
Installing SharpAL-1217 on my Acer Aspire5701Z
If your system is running Vista, then U cannot install your sahrp copier for now until their is a compatible driver for vista.
But if U are using windows XP, then try downloading the Copier's driver from sharp.com
hope this helps
2answers
Sharp AL-1644 and vista 64
The quit making drivers for this product in 2005. Only Windows XP and below is supported.
http://www.sharpelectronics.info/Software.aspx
Sharp AL-840 laser printer; installing driver
hey beth
sure. ill go and look for that driver for your Sharp AL- 840 now and ill post it here.
2answers
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
