NO MEDIA stated , CD, DVD, Blueray, DVD-r, CD-R, what?
the acid test if it plays DVDs is to use a real store bought DVD movie , that must play, does it? and see the files on it?
The 1millionth post here, with NO OS stated
windows , right? and what version?
click control panel, click system behold version and 32/64 bits.
vista or XP. both are bad news.
XP is dead now, XP cant get MS. PnP drivers now, from mS
they took all that off line 4 years ago, time to upgrade the OS.
here is what it can be: a list.
did the pc get upgraded or downgraded? Windows
Did the HDD get replaced ever?
This PC is only 11 years old , and HP still supports it.
amazing luck there, no?
It came new with Vista 32 or 64 bit, (microsoft ended sport last year)_
so is it still running VISTA, or w7, w8 or w10 via upgrades
(wise to do)
vista 32 bit drivers are here.
load all those but never mess with BIOS. there.
just drivers.
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv6700-entertainment-notebook-pc-series/3632100/model/3650960
now why it fails, a large list of possible
1: some one up graded it and messed up the drivers.
2: virus infections
3: the drive is bad or needs cleaning,(optics)
4: the HP driver are missing, for it.
5: Disk you are using is bad, or not supported with that optical drive,
5: sure if device manager says its dead, missing red marks or yellow marks or flagged as unknown, the drive is bad or the driver,
drive = harware
Driver = software matching above and the OS unstated by you.
best-buy replaced what, the disk drive optical?
if the PC still has good HDD
power on, and hammer F11 this puts the pc back to day one settings , Vista
and all data lost, and all added Applications gone.
if you had told the OS and told what the label on the DVD drive
says, then a match can be easy but alas you did not.
they must match.
did you right click the DVD drive, and pick update yet?
it will look on local HDD for a driver,
then if missing go to MS and fail , (the pulled the plug there)
leaving only HP support. above,
WoW, that one is a good one.
If you are using Windows OS go to device manager, hardware, uninstall or remove device (DVD player).
Turn off the computer HARD BOOT/Cold Boot, not just reboot.
Start the computer and it should find your DVD add the drivers and install them. That should do it.
NOT all Windows versions are exactly the same, but, once you get to the device manager you should find remove/add devices.
Good Luck
Al at Dallas Texas, USA 785180
SOURCE: hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
SOURCE: HP pavillion DV6500 CD/DVD RW not responding
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
If not than use Philip Screw Driver take out optical drive and put it back in Reinstall CD/DVD Drive drivers using Device Manager .
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
SOURCE: wont recognize cd/dvd drive
First use the following steps:
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If the problem remains, open Disk Management. in XP, click Start-> Run
Type diskmgmt.msc and press Enter
If the CD/DVD drive is listed there, try to change the drive letter for the drive.
If the drive is not listed, let me know.
SOURCE: HP Pavillion dv9000 does not
Hi
This is happening due to a driver issue. You can download the driver for your Optical drive from this link---
HP Pavillion dv9000 Optical drive drivers
Hope this helps.... Please post back in case you need further assistance.
Daniel
