Canon ZR100 Mini DV Digital Camcorder Logo
Posted on Aug 05, 2010
There is a flashing red light on the charging light when the camcorder is plugged in. we just replaced the the back up battery, but the light is still blinking.
Brent Rowlett
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 15, 2015
Brent Rowlett
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2368
Points
Just fixed mine. The flashing red icon tells you that the backup lithium button battery CR1616 is bad. Take the main battery out and behind the battery you will see a little plastic tab to open to gain access. Battery preserves settings when main battery fails.
Anonymous
Level 1:
Genius:
  • Contributor 1,812 Answers
  • Posted on Aug 05, 2010
Anonymous
Contributor
Level 1:
Genius:
Answers
1812
Questions
0
Helped
251547
Points
49
The blinking red light is normal. It tells you that the camera is plugged in and charging.
If this information is helpful to you please give a positive vote
Why doesn't it turn on?
obviously the battery in your system is faulty must replace it.
2answers
I have a flip slide hd S1240W that has not been charged up in a long time. I have tried to charge it and attempted to reset and then charge. All that is happening is a red flashing light but nothing at...
Try removing the batteries, plugging into your computer, popping the batteries back in, and removing. Wait 5 minutes, and plug back in! This should have an affect!
How do I charge my emerson 720p camcorder?
The rechargeable battery needs to be replaced.
Apr 11, 2012 • Cameras
1helpful
I'm having a hard time getting my Flip HD to charge. It is brand new and this is the first time I've had to charge it. Sometimes the red light is on and steady and other times the red light is flashing. ...
I had this charging problem with 2 new Flip Ultra HD cameras...red light flashing..nothing on the screen after plugging in the USB port.
I removed the battery..plugged camera into USB port..pc recognized the camera... installed flipshare software..updated software...plugged battery back in..all good.
Why on earth the book doesn't mention these steps is beyond me.
The red light flashes when its charging
Had this problem myself and found that the voltage of the battery was too low for the camera to charge (2.8 volt,s)
I manually charged the battery up past 3 volt,s then put it back in the camera and plugged it in--the light did stop flashing and did finaly turn green.
Or just get an external charger online for cheep.
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Charging lights turn red and green...But camcorder will not power on
All right if you have the same problem that i had what you need to do is take the battery out the take the memory card out the put the battery back in then try and turn it on if it works then put the memory card back in and it should be fixed
Apr 29, 2009 • Cameras
4helpful
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
1helpful
2answers
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Sharp view cam vl a10
my view cam is blury when you try to play any movies on it.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
