Toshiba SATELLITE A10 A15 A20 A25 A35 A40 A45 SATELLITE PRO M15 SERIES 15 INCH XGA LCD DISPLAY -LQ15 (LQ150X1LHC3B) CD-ROM Drive Logo
Posted on Aug 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My region is 1 and im in region 2, i have 0 chances left can it be changed
Nanny
Level 3:
Genius:
  • Toshiba Master 2,351 Answers
  • Posted on Jul 22, 2019
Nanny
Toshiba Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988777
Points
7262
If you are limited by the region code of discs, you could get a region free player which can enable you to play Blu-ray and DVD discs from any regions. You could try Leawo Blu-ray Player which is a region free and 4K Blu-ray player.
Anonymous
Level 3:
  • Toshiba Master 32,281 Answers
  • Posted on Aug 05, 2010
Anonymous
Toshiba Master
Level 3:
Answers
32281
Questions
Helped
7907442
Points
102259
You can only change the region code 4 times, on the 4th change the DVD player will be locked to that region.
To make your player region free, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
2answers
Tried to unlock the region on a samsung d530 now nothing works. Can i restore factory settings? thanks
Here is the steps to make your dvd player region free:
1. get the system grid to change region.
2. change to region 2 first.
3. then change to all regions.
Part 1 -> Getting to the grid
make sure the disc tray is closed
press buttons below one after each other
1) Repeat
2) Fast Reverse (3) Next Ch (>>')
4) Fast Fwd (>>)
5) Prev Ch ('6) Play (>)
Take a note of the highlighted numbers (just in case!) in
case you need to do it all again.
Part 2 -> Change player to region 2.
Using the grid make your player into region 2 by
highlighting the numbers 2,8,19,21,22,24 then PLAY button to
save settings(this will turn your player off - you need to
turn it back on by pressing power button
Select the language again then proceed to part 3.
Part 3 -> Change player to region 0 (all regions)
Press the following buttons:
1) Repeat
2) Fast Fwd
3) Fast Rev
4) Fast Fwd
5) Up
6) Down
You should see a 0 on the top left corner!!!
Player is now REGION FREE.
1helpful
3answers
I want to change the region code on my sony slv d281p
I dont know is this work in your brand, but we dont lost nothign whit try it:
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
Hope helped.
1helpful
2answers
Not reading the disc
need a bit more info - are you playing a movie or running software installation?
If you need to change the drive region then do the following
1. Power on your DVD Player without a disc in the drawer.
- Wait for the "Loading" screen to finish and then the display reads "no disc".
Check which region your reader was bought in. (Large Number label is located on the rear of the Player. Region 1 to 6)
-on the remote control
2. Press the "Repeat"button. The "no disc" label on the screen will disapear.
3. According to the region your player was bought in, choose from the following button sequences.
- region 1, press buttons 2, 9, 3, 3, 4
- region 2, press buttons 5, 7, 5, 3, 8
- region 3, press buttons 5, 6, 7, 3, 2
- region 4, press buttons 7, 6, 8, 8, 4
- region 5, press buttons 5, 3, 8, 1, 4
- region 6, press buttons 2, 4, 4, 6, 2
4. The number in the top left corner of the screen shows you the current region. EG "1" for the US/Canada, "4" for Australia/NZ.....etc.
5. Now enter the new number for the region you require (1 to 6)...or simply enter 9 for "Multi-region". The number in the left hand corner of the screen will change to the number you enetered. Wait for the number to dispear. It will take around 15 seconds.
6. Now power off the DVD player with the button on the front of the unit. Now each time the unit is turned on it will be in the new region...or muti-region if region 9 was chosen.
7. If you wish to change the region again...or back to its original, go through the exact same sequence until step 5. Then you enter the different region number.
If you are unsuccesfull with the above code then it may be worth trying one of the resources below.
2answers
I CANT CHANGE THE REGION ON MY DVD, although I have 1 change left
you can flash the drive with region free firmware (best option if you know what youre doing)
you can reinstall os giving you extra tries.
or you can use a program called any dvd(free)which enable you to watch any region (safe)
flash is best if youre not sure or cant find software let me know and give your dvd details(firmware)
eg freecom dvdrw 523252
1helpful
2answers
Changing the DVD Region code
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
The first solution is free VideoLAN player: click here to download VideoLAN.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition Click Start Player button, and try to play your DVD
Finally Load another firmware for your DVD drive which disables the region code protection.
3answers
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
I would like to play dvds region 1 and 2 by having laptop unlocked
Go to 'my computer' right click on you dvd drvie, go to properties, click on hardware, click on properties, then on region and change the region to region 2. Please note though that you can only change the region settings a certain number of times. It will tell you how many times you have left remaining when you go to change the region settings.
hope this helps
Dvd region seems locked
you can also download softwares like dvd region code breaker, then watch movie
Region codes for philips dvd 722
on these dvd players you can only change your regions 1 ,2 or 3 times and then they wont change any more. sorry I couldnt help
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
