SOURCE: not able to set up GPS in my HTC p3300 in india
It sounds like your not able to access the internet on the device , try going to a normal webpage and then you can check if it loads it most probably wont. if that is the case you will need to contact your network to get the settings. ( Most networks will brand the device with there own name it can be helpful to find what this is before calling .) once you have done this then you will be able to download the quick gps settings . The special GPRS mentioned above is only the networks name for there GPRS service.
After this is done you may notice that you still arent able to use your GPS to find your location that is because you need to select the port that the GPS device is on
1.Tap start > settings
2. Tap the system tab
3. Select the GPS option
4. In the drop-down box that is entitled GPS program port select COM4
5. Tap Hardware tab , Gps hardware port should be ( None ) and baud rate 4800
6. Tap access tab and then select manage GPS automatically tickbox
7. Now click ok then x
You will now need to setup MAPKing to use COM port 4 as the GPS device this will now allow you to use your GPS properly
SOURCE: GPRS with AIRTEL on HTC P 3450
GPRS service is there in airtel but there is no wap service for the htc mobile 3450... as i am using the phone i will browse the sites through GPRS by Internet Mobile Office
SOURCE: how to unlock Htc Touch Diamond !!
follow my shared experience to ulock HTC Touch Diamond. Was locked with Orange operator in UK
http://internetbisnisonline.co.cc
over at xda forum the scumbags are charging people for the unlock software i got free from a german friend. this definatly unlocks htc touch, diamond, pro exc its really tricky to excute the last stepsbut it definatly works. all you need to do is join this site free and search for diamond_unlocker or browse through our ppc setion you will find it as i said its free of charge to join and download instructions are very easy to follow after you have completed steps 1-3 you need to flash a new radio. http://www.extremplanet.co.cc/forum/
