Intex Challenger 3 Boat Kit Logo
Posted on Aug 05, 2010
Setup install continue ......... because errar..
Setup install continue ......... because errar.. please plag-in device for web cam driver setup ...........
My built-in web cam is not working.
How much has this laptop been used?
If it's been opened and closed a lot, if Windows doesn't find the web cam at all, it's quite possible the wiring is damaged for the web cam between the base and the lid, probably where it passes through the hinge. In that case, it MIGHT work when the lid is in certain positions, and not work when it's in other positions.
The wiring can be replaced - replacing that wiring bundle is a common repair. Have you EVER spilled liquid on this laptop?
It doesn't matter whether it was running at the time - it can be damaged even if it wasn't, because the mboard is always powered in some places when the main battery is installed. Has this laptop EVER been dropped? Have you re-loaded Windows from scratch from a regular Windows CD since the web cam last worked? If you have, you must load the main chipset drivers after Setup is finished, otherwise Windows will probably not find all your devices properly. Look in Control Panel under Scanners and Cameras - do you see anything there for it? If you don't, did you try using Control Panel - Add Hardware to see if Windows can find it, or some unknown device? If you don't see it there, Windows Add Hardware can't find it, it's wiring is probably damaged. If you do see it there....
Did you un-install any drivers listed in Control Panel - Add/Remove Programs for the web cam before you installed the drivers? If you didn't, do that, reboot, and try installing the drivers again.
Note that is often NOT a good idea to install drivers for something when Windows detects a device while booting, you allow it to look for drivers, then when it doesn't find any, you point it to where the driver files are. You should Cancel that if you see it, continue on to the desktop, then install the drivers using it's installation program, or follow installtion instructions - there may be a Readme or similar file in the download when it's files are extracted, or included with the download.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
3answers
My cam does not work on person.com but works in Yahoo MSN and Hotmail Messenger. Can anyone help me fix this probles. My cam is an in-built in laptop.
Go to this site and sign-in.
http://person.com/webcams.personals_search.phtml
then go to webcam and click on it and setup your camera so it will operate on person.com. All web cam's have to be setup on a program so it will operate properly.
Hope this helps. Bud
2answers
The install shield doesn't finish working
Try copying the files on the disc to a folder and run them from there. Open the folder you saved the files in then double click the setup.exe icon and see if it completes the installation. If that does not work then try downloading the files from the radio shack web site.
3helpful
2answers
Install A4 tech PK635 M web cam without cd installer
Hi, The drivers and software are available for free download from the manufacturer. Click the link below and the save the file. When it's done downloading, open the file and run the installer/setup file. http://www.a4tech.com/ennew/driver/CameraA.zip Chris
2helpful
3answers
WEB CAM CD LOSE
install driver genius 2007 then connect ur cam & select the drivers u want to download
please vote for me
My laptop motion eye
Please check in the Device Manager under "Imaging Devices" whether the "Web cam driver is listed". If the Web cam driver is not listed then install the web cam driver either using the Recovery Discs or from the location "C:\Drivers". Please do restart the Computer after installing the driver. Even if the web cam driver is listed under the "imaging devices" in the Device Manager then right click on it and unistall then restart the Computer and reinstall it. Next, use any video utilities such as MSN or any other to check if the web cam is working normally. It's required to configure web cam in the utilities to be used with any other utilities.
Creative Web cam VF0090 is not detected by Web Cam Cntr
sound like a corrupt driver file on the installation cd try this one
We are currently negotiating with our Hosting company to Add over 100,000 Windows Drivers for
Windows VISTA
Windows XP
Windows 2000
Windows 2003
This we hope will allow all users of the site to be able to find the drivers
they need at any time without having to trawl the many dead ends on the web
so spread the word and bookmark our site.....
The site and drivers are absolutely free to download and use...
the cost of this will be born in 3 ways
1. PC Leeds will donate time and site costs.
2. Revenue from google ads.
3. Donations from site users.
so there are a few ways you can help keep the site up and free.
visit www.pcleeds.com/drivers.html for more info.....
8answers
CANT INSTALL DRIVER
since you have not given any model no for your ibm web cam, Its very difficult for anyone to tell which drivers to download
visit this link to scan for your web cam drivers:
http://www.softwaredriverdownload.com/ibm_33l4889_pc_camera_windows_2000xp_driver.html
installation:
  • Make sure the IBM PC/Net Camera is unplugged from the computer before installing this software.
  • Click [YES] to continue, the exe will then extract setup files to c:\\setup folder.
  • Go to C:\\setup folder, you will find Setup.exe there, double-click to run it.
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
dilipbagdi
Webcam drivers installation
try to update the drivers from device manager and scan for new hardware...
Top Intex Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you an Intex Boating Expert? Answer questions, earn points and help others
