Nikon DSLR D90   Digital Camera Logo
Posted on Aug 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Nikon D90, after taking a series of pictures, when I down load them to my computer I notice that the camera has taken two picuters of each subject, one is bright and the other is dark and in shadow, how do I set the camera so I only produce one picture each time?
Anonymous
Level 2:
Novelist:
  • Expert 88 Answers
  • Posted on Dec 03, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
88
Questions
0
Helped
35543
Points
239
You have auto-bracketing on. It's the little button labled "bkt" by the D90 logo in the front.
I bought used nikon d90 from the shop of greenhill, Philippines, is this good camera for semi professional user, any adjustment for bright color image, thanks
first you should try to reset the camera to factory settings. then check again.
if it does not give the effect you were expecting, you can adjust the brightness and colour balance (not the same as white balance in pictures taking. the only thing you can't is change the brightness of the display.
i have a link for a free download of the manual, from nikon usa here:
http://cdn-10.nikon-cdn.com/pdf/manuals/kie88335f7869dfuejdl=-cww2/d90_en.pdf
then i do have a link for a youtube film about the use of the d90.
how to use nikon d90
enjoy the camera.
if it does not work as expected, just bring it back, but i don't think you won't like it.
How to set self timer for D90
Instructions for this are on Page 179 of the D-90 users manual. First go to the menu and select the custom settings menu then scroll down to "timers/AF Lock."
Select this then select the number of shots you want the camera to take at one time on the self timer setting. Exit the menu.
Then go to the top of the camera and find the little button to the right of the control panel which contains a series of stacked rectangles.
Depress this button (camera must be on) and the control panel will clear. Rotate the wheel on the back of the camera while holding the button down until you see a little clock symbol.
If you have set it in the menu to take only one shot, you will see only the little clock. If you have set it to take multiple shots you will see the series of stacked rectangles next to the little clock.
Depress the shutter fully then walk or run to get in the picture. Just before the picture shoots, the autofocus light will flash warning you that the picture is about to be taken. The camera will shoot in the amount of time you have selected in the menu.
If you want to shoot another delayed shutter picture, repeat the procedure using the button and wheel.
Nikon D90 the mirror is locked half way. I can see half the picute and camera shutter works okay
You obviously need to send it out for service. Don't try to fix the mirror yourself or even touch it. It is extremely fragile and is silvered on the front, not on the back like a regular mirror.
4helpful
Nikon D90 and memory card counter
There doesn't seem to be a problem. The 3.7k means 3700, the k meaning thousand. If you were to take about 2700 pictures, you'll then see 999, then 998, and so on.
7helpful
My Nikon d90 monitor does not display when I turn it on.
By default the D90 is set to use the viewfinder for framing and taking pictures. If you wish to disable that and use the monitor, press the "LV" button on the back just above the multiselector.
1helpful
Nikon D90 that does not want to shoot pictures
The camera may not be sensing that a lens is attached. Try removing the lens completely and then attaching it again securely.
2answers
Nikon D90 ERR message after taking picture -
Is there a memory card in the camera?
Also try cleaning the contacts on the lens (light rub with a pencil eraser works).
Nikon D90 takes pictures, all pictures are black!
I think its your CCD. If its new take it back. Nikon will fix it for free
1helpful
3answers
Cant download pictures usb
Take your sd memory card out of your camera, and put it in your computer. A file with your pictures should appear. Copy thoes pictures into a different fold on you computer. Take you sd memory card out of your computer and plug it back into your camera. Your pictures will be both on your camera and on your computer.
I hope this solution helps. Please rate this solution.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
