Question about Sony KV-35S42 35" TV
Can I recharge a Sony CRT ? or deep six? - Sony KV-35S42 35" TV
    Top Expert:
  • Sony Master
  • 14,553 Answers
Most shops have a unit made by B&K for testing recharging crts.
We call it hitting a tube, but most of the time if it works it will last less than a year.
I have done it many times with customer approval and the results can be dramatic.
Considering the age of this set you may just want to let it go.....
SD TECH
Posted on Aug 05, 2010
SOURCE:
6 times b;inking light
Check the horizontal output section circuit. Six blinks of standby light indicates:
  1. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Jun 16, 2012 | Sony Televison & Video
Kv32526 32" sony no picture everything else is ok can hear voices can change channels 1997
you should check the RGB, check the heater voltage from Fly back to the heater (CRT Tube), make sure there are about 5 VAC Voltage, if no damage is usually there at 1 ohm resistors, other than that the damage can be caused by any part of an abnormal color, RGB voltage not equal or one is weak or not functioning. in other words, the color Green or Red and Blue did not appear. consequently it will not appear on the screen image. the solution is to replace the CRT tube or CRT tube Recharge using special equipment recharging....
Sep 30, 2010 | Sony KV-27FS16 27" TV
I have sony bravia klv32s310 six time red led blinking
my sony brawia klv32s310 a main board change.after red light blinking 2 times
how coming this? pls help me
Aug 14, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony wega tv won't turn on. The standby light blinks six times..
sorry, 6 blinks is a bad board!!!will cost around 1000 bucks,just by a new set
Oct 09, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Will not power on
Hi
the clicking sound is the responds of the relay switching and cant continue power up because of you have problem in Regulated power section the (oscillation) and the six blinks is the defective oscillation, this problem need to diagnose to find the bad parts in regulated power section..
Angel
Thanks...
Aug 02, 2009 | Sony Televison & Video
Will not power on, red light flashing six times
the problem is in the power supply most likely. The overvoltage protect circuit is causing you not to be able to turn the tv on. This is common to all tv's. Solution unfortuantely is get another tv unless you know someone who can either work on or replace the internal power supply
Jul 01, 2009 | Sony KP-61HS30 TV
After six yers of flawless use, a notice comes up
try starting the tunning and restoring the programs from scratch
May 02, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony wega trinitron KV-34HS420
did a quick google got this:
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/?page=6
blinking is the self diagnosis working.
Aug 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-20FS120
You need to replace its Picture Tube (CRT). Its CRT's defect.
Jul 29, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony KV-35S42 35" TV Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
