Guys, I just realised that there is a mark called AC on the back of the module next to a gold small circle pad. Once you change the battery, you need to connect a wire or paperclip or something similar between the back or positive of the battery and the pad, it should then come alive. Good luck
You can find manual here http://www.usersmanualguide.com/casio/watches/qw-1044
there is no summer time adjustment ,you have to add or remove 1 hour manually
my mail is [email protected] if you need other help.
When you open it there are 2 batteries ... you change one at a time... never take both out at the same time... its easy procedure... one is back-up for the other.
I just did it..
I have a question thought - do you know how to get the summer time adjusted on it ? I dont have a user manual for it.
Thanks
Salam you need to put one new battery (the top one - magnet sensor shoud be at your right or (that with the protective plastic holder)
keep it for 3 days and then put the botton one on and here you go it is up again, I tried it on 3 diffrent watches and it work.
make a duaa for me
Assalamu Alikum,
M Subhan,
my boss gifted me the cpw-310 , in Compass when I try to get the qibla direction , my display shows BATT..
dont' know why.. please help. and when I try to calibrate the campass it shows BATT.. please help me to solve the problem
(CPW-310) Opps! I took both batteries out at once & changed them, now I don't hv any display or anything........Do I hv to reset something, pls can any one help?
Hi al_laith1,
I just wanted to ask zou how have you done to change the battery? is there any special tool needed? Thanks a lot
