OK... just by the size of the cards you are most likely using a 2gb card that is an SD, which is perfect for it is what this camera reads.
the 8GB card is probably an HDSD card. This is not read by this camera.
They look the same, except are labeled differently.
Here are the specs on your camera: http://www.imaging-resource.com/PRODS/TZ1/TZ1A.HTM
here are the specs on the cards: http://en.wikipedia.org/wiki/Secure_Digital
Note how the specs of the camera define the memory card to be used is an SD card.
The DMC-TZ1 is designed to work with SD cards. The 2GB card is an SD card, while the 8GB card is an SDHC card. While SDHC cards will fit into an SD device, it will not work.
Some cameras cant manage/format large size memory cards as they where not made to handle that size. Check your user manual which should tell you the maximum size memory card your camera will take.
Problem: More than 2GB of RAM is installed, yet the 32-bit OS only sees 2GB.
Cause: Memory remapping is enabled.
Solution: Enter Computer Setup (F10) and disable memory remapping: Advanced > Chipset/Memory.
