Disconnect the power cable open the case and pull the CR 2032 battery out for a minute. That will reset the BIOS. If you have no Beep Codes at all the MoBo might be dead. If this were just a video issue there'd be Beep codes. If there's more than one stick of RAM Pull one try to boot then do same with second stick. if there's only one stick of RAM try reseating it.
SOURCE: T6534 WANT BOOT UP. SYSTEM RUNS INSIDE.POWER SUP?
You power ratings are ok on the main power supply. But you should check the volts on the internal and see what is happening.
SOURCE: System will not power on.
Hi Robert,
Have you checked to see that there is no cabling of any sort in your machine that may be brushing with the side panel when it is closed? I'm thinking maybe a GRND pin from either the front panel connectors or a USB connector but this is only a guess. I am unsure why a panel could stop it turning on! Let me know if its resolved! :o)
SOURCE: emachine wont start
How many hours you working you computer? 1 or 2 or 3 hours?
if you working 2 or 3 or 1 then automaticaly shutdown then, when you push the power button the cpu fan is working but in few minuts shutdown again,.... check you cfu pan maybe this over heting only.. try to make cold the computer then start again if dos't work.. check the power connnection in the motherboad........
SOURCE: PC power down after 3 seconds power on. Power
pull out the cpu chip and see if it comes on or beeps,
If it dont its the mobo.
Sometimes the mobo and the cpu go bad at the same time, a bad cpu can kill the mobo
