Hi There,
If you're trying to describe the BIOS password, then this link is the best information website on the subject I've ever run across. Best of luck....
http://www.tech-faq.com/reset-bios-password.html
You need to take out the RTC battery. First, unplug the computer, next remove the large battery, finally do the following
1. Prepare the computer for disassembly (above)
2. Remove the memory/Mini PCI module compartment cover
3. Remove the Mini PCI communications module
4. Remove the RTC battery from the socket on the
system board.
5. Removing the RTC Battery for 10 minutes
Reverse the above procedure to install an RTC battery.
Removing the RTC battery resets the BIOS which resets the password.
SOURCE: reset power on bios password on compaq 2200
theres a small battery in you computer you have to pull for like 5 minutes you can find out what it looks like on youtube.com or wonderhowto.com
SOURCE: I have HP compaq peserio 6720s laptop.
Look around the Internet for a blank administrator password CD. You can find various ones to download (like UBCD) and then create a bootable CD. Once that is done, simply boot, using the CD, and follow the prompts to blank the administrator password. Log in using the admin account and create a good, strong (but memorable) password.
I hope this helps. If it does, please rate the solution.
Regards,
Char1ieJ
SOURCE: hp laptop 6720s indicates power-on password with a key icon
Sounds like the hard drive was locked, or the BIOS was locked. If the hard drive was locked, you must replace the hard drive. if the BIOS was locked you willl need to reset the bios. You can likely remove the CMOS battery to reset the bios.
SOURCE: i have a compaq laptop
If you dont know the Power on password for your System, forgotten it, or its not accepting it
again, then you might have to reset your CMOS.
Which means you will have to unscrew your system, remove all cables supplying power to the
board, locate the CMOS battery and remove it for a few seconds, then replace it and screw your
system back.
This will reset your system's CMOS back to its Factory default settings.
(If you can't unscrew your PC yourself, you can just get a good technician to do it for you
instead.)
Hope it helps.
