The air pump for the secondary air system (emission
control device) is located under the battery. If you do replace it,
replace the check valve too, it is on top of the exhaust manifold and
connected to the pump with a hose. The check valve fails and ruins the
pump.
Source(s):
http://repairpal.com/volvo-850-1997/comm…
http://repairpal.com/air-pump-check-valv…
OR
I think they are talking about the pump to provide
vacuum to the climate control when the turbo is putting boost in the
intake manifold. The vacuum can come from an electric pump or from an
engine driven pump, something like an old engine driven fuel pump. I
needed an electric pump for my 765T, and all the wrecking yards wanted
to sell me the engine driven form. (A new one was $500, and it wasn't
that important to me.)
An engine that takes the engine driven pump will have a hole in it while
the others will not have a hole.
Source(s):
35 years maintaining my own cars,
including 17 years with a 1985 765T
OR
Rear Suspension Leveling
Air Compressor
RH front of vehicle, attached beneath the fascia
Rear Suspension Leveling Air Compressor Relay K19
Lower I/P, to the RH side of the steering column, on the relay box
Automatic Level Control
System Operation Check
Support the rear wheels or support the rear lower control arms when
certain tests require raising the vehicle on a hoist. Use two additional
jack stands in order to support the rear lower control arms in the
normal curb weight position when a frame type hoist is used. Refer to
Trim Height Specifications in Suspension General Diagnosis.
Refer to ALC Suspension System Check for electrical troubleshooting of
the Automatic Level Control (ALC) system, or if DTC's are present.
Diagnosing Leveling Complaints Without DTCs Present Procedure
Perform the following preliminary inspections before performing the
system performance test:
Inspect the ignition (pin A & pin H) at the ALC sensor connector.
Ensure that the ignition (pin A & pin H) at the ALC sensor connector
connection is secure.
Inspect the ground (pin E) at the ALC sensor connector.
Ensure that the ground (pin E) at the ALC sensor connector connection is
secure.
Inspect the ALC sensor link.
Ensure that the ALC sensor link is properly secured to the actuator arm.
Inspect the ALC sensor actuator arm for damage.
ALC Diagnosis Table Step
Action
Value(s)
Yes
No
Has the ALC compressor assembly and the air tube been replaced?
Go to Step 7
Go to Step 2
Raise and support the vehicle. Lifting and Jacking the Vehicle in
General Information.
Inspect the air tubes running from the ALC compressor to both rear shock
absorbers.
Inspect the air tube connection at the ALC air dryer.
Are the air tubes damaged and/or disconnected?
Go to Step 13
Go to Step 3
Squeeze the left rear shock absorber in the middle of the air sleeve.
Did the air sleeve slightly compress?
Go to Step 5
Go to Step 4
Operate the ALC system for 60 seconds.
Test the air tube-to-air dryer connection for leaks using a soap bubble
solution.
Is a leak evident?
Go to Step 20
Go to Step 5
5
Disconnect the air tube from the ALC dryer.
Connect the Pressure Gauge to the ALC dryer.
Close the toggle valve on the Pressure Gauge .
Operate the ALC compressor.
Did the pressure build to the specified value?
80 psi
Go to Step 6
Go to Step 10
6
Shut off the compressor when the pressure reaches 80 psi.
Monitor the gauge for 1 minute.
Did the pressure leak down?
Go to Step 10
Go to Step 7
7
Connect the Pressure Gauge to the right rear shock absorber. Ensure
that the toggle valve on the Pressure Gauge is away from the shock
absorber.
Close the toggle valve.
Pressurize the shock absorber at the toggle valve on the Pressure Gauge
to 80 psi.
Did the system leak down?
Go to Step 11
Go to Step 8
8
Use the toggle valve on the Pressure Gauge in order to slowly release
the air pressure.
Disconnect the Pressure Gauge from the right rear shock absorber.
Connect the Pressure Gauge to the left rear shock absorber.
Pressurize the Pressure Gauge to 80 psi.
Go to Step 12
Go to Step 9
9
the air pressure.
Disconnect the Pressure Gauge from the left rear shock absorber.
Connect the Pressure Gauge , inline, at the tee near the rear of the
vehicle.
Reconnect the air tube to the ALC dryer.
Open the toggle valve on thePressure Gauge .
Using shop air, pressurize the system to 80 psi at the service
connection of the Pressure Gauge .
Monitor the pressure gauge for 1 minute.
Go to Step 14
Go to Step 20
10
Replace the following components:
• Replace the ALC compressor. Refer to Air Compressor Replacement .
• Replace the air tube. Refer to Air Tube Replacement .
Are the replacements complete?
Go to Step 20
11
Slowly open the toggle valve on the Pressure Gauge in order to relieve
the air pressure.
Replace the right rear shock absorber. Refer to Shock Absorber
Replacement in Rear Suspension.
Reconnect all of the air tube connections.
Is the shock absorber replaced, and are all of the air tube connections
reconnected?
Go to Step 20
12
the air pressure.
Replace the left rear shock absorber. Refer to Shock Absorber
reconnected?
Go to Step 20
13
Are any of the air tubes damaged?
Go to Step 14
Go to Step 18
14
Replace the air tube that runs from the air dryer to the two rear shock
absorbers.
Is the replacement complete?
Go to Step 15
15
Remove the ALC air dryer from the compressor assembly.
Shake the ALC air dryer with the head connection down.
Did water/moisture come out of the ALC air dryer when the dryer was
shaken?
Go to Step 16
Go to Step 17
16
Replace the ALC air dryer. Refer to Automatic Level Control Air Dryer
Replacement .
Go to Step 17
17
Replace the air compressor head. Refer to Automatic Level Control Air
Compressor Head Replacement .
Go to Step 18
18
Install the ALC compressor on the vehicle.
Is the ALC compressor reinstalled, and are all of the air tube
connections reconnected?
Go to Step 20
19
Repair the air tube-to-air dryer connection leak.
Is the repair complete?
Go to Step 20
20
Reconnect all of the connectors that were disconnected.
Reconnect all of the components that were removed.
Clear all of the codes with the ignition ON and with the engine OFF.
Wait at least 5 minutes.
Is the rear of the vehicle trim level?
System OK
