SOURCE: blank screen ibm r40e
This is generally a memory problem. Remove the memory, and try them one chip at a time in each slot. If the memory isn't the issue, then try removing the battery and starting with the supply only. Both battery and memory can cause this, but the beep code is generally for the memory, no beeps with the battery. If both check good, then test the power supply with an ohm meter for the proper output. If these three check good, then the problem will lie within the motherboard, and you will need to take it in for a professional diagnosis in order to track down the exact problem area. You might also look on IBM's support site for the beep/sound error codes and any troubleshooting for the exact code you have.
SOURCE: Link for IBM R40e drivers and guidelines
Here's a link to IBM's support site for the R40 drivers. You can narrow down the list by choosing your operating system and other applicable categories. I recommend that you write down the address and also save it in your favorites for future use.
http://www.ibm.com/products/finder/us/finders?Ne=5000000&tmpl=%2Fproducts%2Ffinder%2Fus%2Fen%2Ffinders&finderN=1000188&pg=ddfinder&lc=en&cm_re=other-_-suprcn-_-download&collectionN=0&sid=889749551220632021996&cc=us&Ntt=R40e
SOURCE: Searching for LAN driver for R40e IBM thinkpad
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-46024
There u go M8!
All avalible drivers for that R40e of yours:)
Good luck
Nic
SOURCE: Required Ethernet drivers for IBM thinkpad R40e
http://www-307.ibm.com/pc/support/site.wss/MIGR-46024.html
This will be helpful i guess, can download it frm here.
SOURCE: My IBM Think Pad R40e fan problems
sounds like you have dust in the vents, try using a revers vac to blow through the vents and get the dust out.
