There is a direct tv box already connected, but trying to connect a dvd player as well and thought could plug dvd directly into tv and change input source with remote, and that is where i am stuck
Are there not enough ports? You can buy port splitters to add more connections to your tv. Also, some surround sound receivers have port switchers too.
Please give more information if this of which I have provided is not good enough. Need more description of the problem.Please give more information if this of which I have provided is not good enough. Need more description of the problem.
You can't post conmments that contain an email address.
Troubleshooting Tips
1. If your HDTV or TV has multiple inputs, make sure you choose the right input your DVD player is connected to, such as Video, HDMI 1, HDMI 2, HDMI 3, Component, etc. Change the INPUT or source the HDTV is set to by pressing the INPUT button on the TV or its original remote. When you try different inputs, let the DVD player play a disc and output a constant signal.
2. If your TV has the correct INPUT or Source, unplug the cable and plug it back, or try another cable or port. Sometimes cable can short-out. Be sure they are connected securely.
3. Test if your DVD player works on other TVs. It could be your DVD player breakdown that leads to No Signal on your HDTV.
4. Try connecting your DVD player to another HDTV if your DVD player works correctly.
5. Check if your DVD player is compatible with your HDTV.
6. If the TV does nt work try to upgrade your DVD.
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
What you have to do is select the proper item on the receiver since that is what you have the dvd player connected to. Pressing bd/dvd on the receiver is not necessarily the right thing to do. All receivers have an input or source or function button that will enable you to choose the correct area where your device is connected. The way you have this hooked up may not be right but first things first. You will need to have a movie playing in the DVD player so that you see the numbers advancing. Go to each input/source/function on the receiver until you hear the DVD. Ok great! Now getting the picture is a little more tricky so please follow along carefully.
The cables going from the DVD player to the receiver: The cables should be connected to where it says OUT on the DVD player or hdmi out from the DVD player to one of the receivers INputs. Once that proper connection has been confirmed make sure the receiver is connected to the television for both video and audio. You must have a video cable as well as audio cables between the television and the receiver or an hdmi cable. If it is not connected to the television in this way that is the problem right there. In fact you probably have a cable going from the television's audio OUT going INto the receiver. In order to see your DVD player you will also need to connect the receiver's video OUT to the television's video IN.
You will need the television's remote to be able to change the source/input/video/aux on the television. You might be able to change it with the cable box remote by pressing tv and then input/source/video.
ALTERNATELY: You can connect the DVD player's Video OUT directly into the television's INput. The DVD player's Audio OUT cables would be connected directly to the receiver's IN.
Either way you will have to choose the correct input on the receiver as well as on the television itself. Good luck!
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
You need to make sure that you change the input on the TV. It is most likely AUX1 or video input 1. Look on you TV remote for a button that says "input" or "source". Make sure your DVD player is on, press press play, then hit the input or souce button on the remote.
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
Check your remote. On my Sentry 2, the magic is the SOURCE button, which allows you to access the AUX (auxilliary) channel. This is what you need to select to view your DVD output.
