Try a clean install:
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Open the Windows Control Panel.
2. Open the Add / Remove Programs window.
3. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the software. Next , do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions,
please feel free to post them here.
P.S. Before you assign a rating, please
make sure that the issue is resolved or you are satisfied. If not, please post
back as to what you did, and/or any other questions you may have, and I will
try to assist you as best I can. Please do not assign an ‘Inappropriate’ or
‘Thanks for trying’ rating if your issue is not resolved after the first
response itself, as sometimes a bit of to and fro dialogue may be necessary
before we can find a fix or an answer to
your query.
If you find that the solution/answer I provided led you
to, or resulted in a fix, please close the ticket with a FixYa! rating.
I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Just wanted to inquire if your issue is resolved, or if there is anything
further I can do to assist you…
to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
rating under my solution. I would be very grateful for your show of appreciation.
Should you have any further questions, please feel free to
post them here.
Cheers!
IrishDruid
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved."FixYa!"
- The solution provides great advice on how to solve the problem.
(Positive Rating)"Helpful"
- The solution provides useful leads that helps solve the problem.
(Positive Rating)"Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated. (Negative Rating)"Inappropriate"
- The solution has absolutely nothing to do with the problem. (Negative
Rating)
If your issue is not still not resolved, do not
assign a rating just yet. Please post back as to what steps you took, results,
etc, and I will try to assist you further as best I can.
IrishDruid
