The colors are just a guide. Assign a color to each port ie yellow to video red to audio left et el and plug the other end into the same
You don't give much information. Coax from what broke off? TV antenna, or from something like a DVD or Dish or DIRECTV? Depending on where it came from, you might be able to use ylw, white, and red. If wherever the coax comes from has those outputs, simply use a ylw, red, and white cable and run to an available input on your TV. Having a VCR and DVD player already hooked up makes no difference whatsoever, as long as you have more inputs available. If you are out of inputs on your TV, you can buy a "video switch box" which allows you to use only one input on your TV, which keeps you from switching the TV input back and forth, by pushing a button on the "video switch box" to choose DVD, VCR, Dish, or whatever. (Yellow is video, red and white are left and right sound). Or, you might have red, blue, and green out put on your device. If you do, run them (using a cable with the same color scheme) to the appropriate input on your TV. BUT: you can get a new coax cable with connectors on each end for a couple dollars most anywhere, that would be easiest.
SOURCE: Hook up vcr
The new Sony does not have the coax connections. It is crazy! If your cable box doesn't have the Audio/Video cable, you have to get a different box from the cable company. I find this new Sony annoying! I am trying to connect it also and when I attempt to use "Setup," I am getting a message that says "no S video detected." Somehow I get the Setup screen sometimes but when I attempt to use the up/down arrows to set stuff up, it changes my tv setting to VGA or HDMI. I am very frustrated with this! Help!
SOURCE: hooking up dvd player
Your cables are coded red(right audio), white(left audio) and yellow(video). The cable inputs on the dvd player and tv are likewise coded. Just connect color to like color. In setup, do not
change NTSC! If you should go to PAL you'll never get out of setup and all you'll have is screen roll, as though the vertical hold gave out.
You have wires hooked properly.
On your remote, hit input button, press down arrow once to AV then press right arrow button.
Then watch a DVD.
It worked for me.
Good Luck
SOURCE: hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
SOURCE: DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
