Question about Toshiba Satellite A205-S4617 Notebook
I am having power problems with my Toshiba A205. When I plug in the power cable, my laptop freezes. When I take out the power cable, I need to shut down and restart before I can get it to work. But once my laptop is on and working and I plug in the power cable, it freezes it. Can anyone please help me? Thanks Slick
    Scholar:
  • 83 Answers
Okie thank me a lot first cos i have the solution or atleast the reason... hate me cos i am the bearer of possibly bad news... the problem is at chip level... a processor needs to be supplied with uniform voltage and power for uninterrupted operation whil handling huge calculations it is not capable of withstanding sudden changes in voltages... for this purpose what we have on a mobo is a chip called the core voltage controller this chip makes sure that the voltage sent is uniform... this chip on ur system is blown
2 solutions exists take a deep breathe relax one is to replace the mobo-cost approx400$ take a deeper breathe ask for toshiba assistance instore and get this chip replaced cost 100$(i took the second option costed me 4500 rupees in India)
Posted on Sep 02, 2010
  • richgunga Oct 24, 2010
    This is a big step forward.
    How do you identify the core voltage controller chip?
SOURCE:
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
Toshiba Satellite A205 - S5812 laptop power problems and freezing !
Remove the RAM and clean the RAM module contacts.
Remove the keyboard cable/connector and clean the contacts.
Mar 24, 2012 | Toshiba Satellite A205-S5812 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite a205-5804 has a problem with the main board, when its plug in it freezes but when not , when is used whith the battery it works alright. a repair center told me is the main board, but...
Are you using the original charger or a universal replacement? As loose fitting power plug can cause this problem but so can a loose connection at the power jack (repairable) or a cracked trace on the main board from stress at the power jack (not usually repairable - ie needs a new board). JC
Nov 17, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba A205-S4607 freezes immediately charger is plugged in
It might be the battery,which is causing this problem.Try cleaning the contacts on the battery with a old toothbrush,also the contacts on the computer aswell.
Good luck
Sep 14, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba satellite a205-S5847 cuts off while working
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
Aug 18, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Jul 30, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205 unable to fully shut down
possible setting issue.
If you Go to,
start, control panel, power options, (classic view)
have a look in the power options there, set as needed. there is a few, check them all out.
use disc cleanup,defragmenter, delete temp internet files, in tools on menu bar , delete history,
update the Operating system at Microsoft.
update virus protection and run a full scan.
you should be good if no hardware problems.
Regards.
Apr 16, 2009 | Toshiba Satellite A205-S4639 Notebook
Toshiba A205-S4577
Check your power settings. You might have it set to shut off after a certain time of non-use.
Sep 22, 2008 | Toshiba A205-S4577 Notebook
Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Jul 26, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
623 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
