Did you experience a power event? Go to BIOS (F2), and make sure that RAID is Enabled. If RAID got turned off (power event, BIOS reset), then it will give you that message. If RAID is already enabled, then you may need to repair your operating system. If something else happened (drive failures, drives removed, etc.), then the array may be completely gone. Call Data Recovery services if it is critical you retreive the data.
