The metal piece that the pressure hose attaches to is cracked. This metal piece is an interior part that is attached to the pump mechanism by 4 Allen key type bolts. I would like to replace this part but I am unable to find the part number for this item. I believe that the Simoniz S1400 Pressure washer is really a Karcher K320. The unit was sold in Canada. A parts break down of this unit would help. Or perhaps there is a way to MacGyver it.
Most of the Simoniz pressure washers are, in fact, rebranded Karcher pressure washers. You can't find support or documentation on their website for machines they no longer make. However, there is a handy dandy website that you can use to find older versions of the Simoniz website, which does have the information you are looking for. I took the liberty of completing the search for your machine: https://web.archive.org/web/20071219120252/http://www.simoniz.ca/productdetails.php?s=6&c=1
I also managed to find a parts diagram and a parts list on a website that sells replacements parts:
Diagram:
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/HD1400CA%20(2003)%20&%20HD1500CA%20(2004)%20EXP%20DWG.pdf
List:
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/HD1400CA%20(2003)%20&%20HD1500CA%20(2004)%20PARTS%20LIST.pdf
Cheers!
Elf
THE PICTURE SHOWN IS NOT AN S1400
Try momarch
I have the same unit. Can not find a parts diagram. In the above picture, to the right of where it's broken, there is a gold spring, (piston?). this is attached to what looks to be a switch for something. I have water shooting out of the gold spring. The pressure is low. Can this be fixed? Is there an online parts diagaram?
Take the part off a good welder should only charge 10$ to fix it for ya and no tracking down parts...
Check out www.pressureparts.com
Stay away from crapy Simoniz. Life will be good then.
I have the same problem as this guy above who wrote:
(I have the same unit. Can not find a parts diagram. In the above picture, to the right of where it's broken, there is a gold spring, (piston?). this is attached to what looks to be a switch for something. I have water shooting out of the gold spring. The pressure is low. Can this be fixed? Is there an online parts diagaram?)
I can seem the find out any info on it either. Please Help!!
i have a simoniz 1400 karcher work ok but it will not go off went you let go o f spray gun , have to shut a switch off . will sell it for part if intrest
When hose attached to unit and water switched on it goes through the pressure washer and leaks out the front rather than just through the pressure hose
not enough pressure
