Toshiba Satellite L15-S104 Notebook Logo
Posted on Apr 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Steps to replace DC power jack L15-S104
I need to replace (or resolder) the dc power jack on my L15-S104 Toshiba Satellite. Could someone give me the steps for disassembly?
Thanks,
Alynn
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
918
Points
I've resoldered my dc jack back onto the motherboard 2 times, but one of the pins is broken off, so the repair doesn't last very long. If the computer remains plugged in and not moved it's okay, but the jack should be replaced to prevent having the problem recur as. The laptop is easy to take apart if you make sure you get all the screws and remove the nuts that hold the monitor input to the case.
A
Anonymous
Same problenmm!!
  • bk6471 Feb 17, 2011
    I have my Toshiba Satellite L15-S104 laptop disassembled right now for the same issue. I used instructions at the following link to disassemble the laptop.
    http://www.irisvista.com/tech/laptops/To...
    Now I just need to figure out how to fix the power jack.
A
Anonymous
I had the same problem with mine..but i havent fixed it yet
Atiq
Level 2:
Sergeant:
Champion:
  • Expert 257 Answers
  • Posted on Apr 25, 2008
Atiq
Expert
Level 2:
Sergeant:
Champion:
Answers
257
Questions
0
Helped
70716
Points
654
Its not so easy to replace you dc jack please don't try your self....
Battery LS15 S104 not charging, got new battery and cable, if it is the dc jack or motherboard how do I remove the cover
If the laptop works with the AC Adapter or Charger and the battery is new you have 2 options.
Either the Battery doesnt work, (if u know someone who has a laptop like yours try it with them)
or your motherboard has a problem in the battery circuit and its not working and you have to either fix it with someone who knows about laptops or change the motherboard
The power conector fired, the board there a hole in this conector. ¿How does repair it?
of course you would want to replace the jack you can purchase it here for under $10.00
http://cgi.ebay.com/DC-POWER-JACK-TOSHIBA-SATELLITE-1400-S152-L15-S104-/170510624449?pt=LH_DefaultDomain_0
If that does not work you going to need to replace the motherboard as a whole
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2helpful
2answers
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
Plugged in and not charging
simple, either the power adapter is bad or the DC jack is broken. The adapter can be tested with a multimeter / voltmeter or by plugging it into another laptop of the same model and checking if it charges that one. If the adapter is bad replace it, if the adapter is good then you will need to take it to a shop to repair the DC jack. Do not take it to geek squad or other big-box retailer and do not pay more that $75 for a DC jack replacement.
2answers
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
1helpful
2answers
CMOS or RTC battery for this laptop : can it be replaced
Hi AshishB, Yes, Toshiba does refer to the CMOS battery in their literature as the real time clock battery. Your retailer is half right, the battery is on the motherboard but its attached via a connector and it can be replaced. Here are links to a couple of venders that sell the RTC battery for your laptop: - Http://www.sparepartswarehouse.com/Toshiba,Satellite,L15-S104,Laptop,Batteries-Backup-RTC.aspx - http://cgi.ebay.com/Toshiba-Laptop-motherboard-battery-cmos-L15-S104_W0QQitemZ170060189842QQihZ007QQcategoryZ3666QQrdZ1QQssPageNameZWD1VQQcmdZViewItem Let us know if you have any other questions and please don?t forget to rate the posting.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
