http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDFhere is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports
duplex printing.
Guidelines for printing on both sides
of the paper 1
�� If the paper is thin,
it may wrinkle.
�� If paper is curled,
turn over the stack, straighten it and then put it back in the paper
tray or the Manual Feed
Slot.
�� If the paper is not
feeding properly, it may be curled. Remove the paper, straighten it
and turn over the
stack.
�� When you use the
manual duplex function, it is possible that there may be paper jams
or poor print quality.
If there is a paper jam, see Paper jams
in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the
User’s Guide.
Manual duplex printing 1
The machine prints all the
even-numbered pages on one side of the paper first. Then, the
Windows® driver
instructs you (with a pop-up message)
to reinsert the paper. Before reinserting the paper, straighten it
well,
or you may get a paper jam. Very thin
or thick paper is not recommended.
Simultaneous scanning, printing and
faxing 1
Your machine can print from your
computer while sending or receiving a fax in memory, or while
scanning a
document into the computer. Fax sending
will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper,
it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
Manual
Duplex
Check
Manual
Duplex.
In this mode, the machine prints all the even numbered pages first.
Then the
printer
driver stops and shows the instructions required to re-install the
paper. When you click
OK
the
odd
numbered
pages are printed. There are six types of manual duplex binding
directions available for each
orientation.
Booklet
Printing
When
you want to print a booklet, use this function. To make the booklet,
fold the printed pages down the
middle.
Binding
Offset
If
you check the Binding Offset option, you can also specify the offset
for binding in inches or millimeters
Can you be more specific? What are you trying to copy? Two sided originals? Odd sized originals?
bizhub 420 konica manolta it becom ready but when order to copy its scaner not move and become restart please tell me seloution
