I have this hard drive its a 52.3 GB it has about 10.1 Used but Windows Says IT has 40 used WTF.Help Please.
AND I HAVE CHECKED HIDDEN FILES.AND I DONT WANT TO FORMAT MY HDD.......HELP
Rcv1962 is right.. i use ccleaner for freeing up space in my system..
Try a program like CCleaner
It can delete all temp files and clean your registry up
You may have to try to repartition the drive, you can do this while installing windows on the disk. If a partition table is corrupted it can make windows think there is more pr less space on a disk, Ive had tables corrupted so bad on dying drives they reported 999999999 gb on a 40 gb drive. you may want to look into getting a new hard drive as well if this is occurring.
You need to tell us more, like what operating system, how many partitions, virtual and real, etc. You need to run Disk Manager and not just look at the properties in the file browser.
We need to know what file system each partition has, like FAT32 or NTFS, etc. You most likely have a back up or restore partition set up by the manufacturer, and that is using up space.
So you need to tell us if this is a brand computer or a generic?
Gphone.pl/przegladprasy/kategoria/Platforma_Android-1/.../losowo
Depends on what you are using the hard drive for. For example if this hard drive is going to be used for multimedia then I would recommend a hard drive around 120Gb to 1TB, but if it's for a small office with MS Windows XP installed it should be just enough to host the operating system and a limited amount of programs, hope this help, best of luck
