Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
Posted on Apr 25, 2008
Jabra BT135 I bought a Jabra BT135 Compact headset and cannot pair it with my phone or any other bluetooth device. It is charged, and I followed the instructions to the T. What's the deal??
  • 1 more comment
  • Anonymous May 10, 2009
    i boughta jabra headset yesterday, and it worked perfectly. i usedit with my 2 differesnt phones, but 2day all of a sudden its refusing 2 pair with my phones, what should i do???
  • Anonymous Mar 23, 2014
    What is the passkey for the jabra bt135
    I need the passkey for the jabra bt135 to link it with my playstation 3
Anonymous
Level 1:
  • Contributor 9 Answers
  • Posted on Apr 22, 2009
Anonymous
Contributor
Level 1:
Answers
9
Questions
0
Helped
9581
Points
35
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
3helpful
2answers
My phone asks for headset in "discoverable mode" How do I get it there?
What kind of phone do you have? I have heard people with LG phones say that it does not pair with their phone. If this is not an issue with you then these steps may be more helpful:
1. Charge your Jabra BT135 until the solid blue LED turns off
(approximately 2 hours)
2. Make sure the Jabra BT135 is switched off
3. To put the Jabra BT135 in pairing mode, press and hold the multifunction
button until the LED stops flashing and turns solid blue
4. Set your mobile phone to "discover" the Jabra BT135 (see your phone
user guide)
5. Press Yes or OK when asked if you want to pair the phone with the
Jabra BT135
6. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK
7. Your phone will confirm when pairing is complete and your headset
will flash
I have it pair to my I phone ----but I lost my manual what are the buttons for?
Follow the instructions mentioned below to resolve the issue:
  • Charge the headset
  • Charge your Jabra VBT185Z until the solid LED turns off
  • (approximately 2 hours)
  • Turning the headset On and Off
  • Press the answer/end button until you see a burst of flashes on the
  • indicator light (LED) to turn your headset on or off.
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
For online pairing assistance visit www.verizonwireless.com/bluetooth.
Hope the above steps allows you to resolve the issue. Please revert back for any further clarification.
Regards
Anand
I lost my old phone I got mynew phone I could not connct my bt150 to my new phone. I need help to pair to my cell phone
Please comment here putting the name and model of the mobile phone you are trying to pair.
With this i can give you step by step instructions on how to go about the pairing.
6helpful
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
5helpful
I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
2answers
Pairing Jabra BT135 with motorola L2
Your not doing anything wrong it usually means that the headset isn't capable with ur razr or you need to reset both of them and try it again. Hope this helps =)
9helpful
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
87helpful
2answers
Bought a Jabra BT135 and lost instructions to install, please help
1. ok when the headset is off keep your finger on the botton until it goes blue (stays blue)
2.when gone solid blue search on your phone for bluetooth
devices and you should find it
3. then it askes for the pairing key type in 0000
4.when you play music while bluetooth hedset is on and bluetooth is on it should play in the headset
Jan 22, 2008 • Cell Phones
3answers
Pairing with a phone
this happened to me too.. i googled a user manual for it.. if i recall it said, turn the headset power off, then once the phone is in pairing mode, hold the power button on the headset till the light stops blinking and becomes a solid blue light. then the headset is in pairing mode as well and your phone should find it
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
