Hi MDoe. I am impressed by the level of detail you seem to put in ur response. Cheers for that.Hi MDoe. I am impressed by the level of detail you seem to put in ur response. Cheers for that.
You can't post conmments that contain an email address.
Both Dell Part numbers 18THT and 5W299 are 8X DVD-ROM Drive Modules. DPN 18THT is compatible with Latitude C series and DPN 5W299 is compatible with Latitude D series. The two drives have different and incompatible connectors.
Your Latitude C640 is a C Series Latitude. You can therefore not use DPN 5W299.
If you need a DVD drive module, get DPN 18THT or an alternative Latitude C series drive.
You can do this yourself Insert the disk into a working computer's CD drive and copy the folders onto an USB flash drive, then insert the USB flash drive into your Toshiba and copy the folders off the USB flash drive onto your Toshiba.
Do the following: 1- Right Click my computer. 2- Select Manage. 3- Select Device Manager. 4- Select from the right pane , DVD/CD-ROM Drive. 5- See what comes under it , and read the letters.
CD-R = Only read CD CD-RW = Read & Write CD DVD-R = Read DVD & CD (mostly write CD also) DVD-RW = Read and Write everything Except DVD-Dl
Check the front of the drive for a DVD logo - if it doesn't have the logo, then it can't read or play DVDs.
If the DVD logo is present on the drive, then you still need a program with Windows in order to play back a DVD video. I'd probably use something along the line of WinDVD from Corel (previously InterVideo).
Good luck, and please rate this answer if you feel it has helped you!!
please check it in different CD or DVD. then check it in a another cd drive attaching to ur laptop. otherwise format your laptop it may be infected with some virus
You probably need to clean out the pc. Get rid of programs that are not needed or used. Do a "Disk Cleanup", Defrag until it takes only about 1-2 min to complete. Get an Anti-spyware/malware as well as an Anti-spyware program and run it once a week.
You might want to also invest in more RAM. 512mb these days isnt much.
Sounds like either there is not enough memory in the laptop to handle what you want it to do, or the operating system needs to be restored. I would try the latter of the two, because that is cheaper, and then if that does not work, then upgrade the RAM
