Cameras Logo
Posted on Aug 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung pl 50 camera does not turn on. The lens come out and goes right back in and it beeps as it turns off
Mukesh Kumar
Level 3:
  • Master 3,230 Answers
  • Posted on Aug 02, 2010
Mukesh Kumar
Master
Level 3:
Answers
3230
Questions
0
Helped
902839
Points
9207
Well it seems that the battery of your camera is dead, first of all you can try to change the battery of your camera, you can purchase the battery from any Samsung store or purchase it from internet (online) by following the below link -
http://www.batterystyle.com/samsung-pl50-battery-p-46502.html
or
http://sterlingtek.com/sb10-samsung-pl50-battery.html?gclid=CMuQjIn6mqMCFdNR6wod9yIaqQ
or
http://www.buy-battery.ca/digital-camera-battery.php/3+samsung+pl50
or
http://www.batterystore.org.uk/store.php/b-1120191-13803-SAMSUNG-pl50-battery
Good Luck!!
Thanks for using FixYa!!
Samsung Digimax S800 camera won't turn on. Beeps three times.
This explains the 3 beeps. also says you can get it repaired which is by far the best option. The behaviour is very typical of low battery state. Try a set of Lithium batteries.
https://www.samsung.com/in/support/cameras/why-camera-goes-off-after-3-beeps/
2answers
The lens on my samsung camera keeps getting stuck. When I turn it on it it beeps a few times and nothing happens,the lens doesnt open or anything. Before that it would justt beep and the lens would not go...
Make sure you have installed freshly charged batteries on your Kodak Camera. If you already have but problem still goes on, then try to do a little fix.
With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. What happens is that there could be a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. If the above solution does not work, you might want to apply a bit of force by twist-pushing the lens inside with your index finger while trying to turn on the camera. The idea here is to remove that grit out of the camera.
Please let me know how this goes. Thank you for using FixYa.
1helpful
Samsung PL 50 lens stuck half way
mechnism of the lens is deffective,get it serviced.
Won't stay on even with new batteries- it beeps then turns off
my camera is doing the exact same n i'm hunting the net right now for some kind of solution!! :( i think its something to do with the lens, mine was completely stuck, but i gently pushed it n it went back in and moves in and out fine, but the cam still comes on for a couple of seconds makes this wierd beep n goes off again!
2helpful
2answers
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
1helpful
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
7helpful
7answers
Sumsung digimax
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time you will hear a clicking noise which is normal once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
