Watches Logo
Posted on Aug 02, 2010
My wife has a Nike Alpha Project watch with new battery. We cannot set the time. I press "Mode" and nothing happens. I hold it down and nothing happens. Perhaps the buttons do not work? Shawn
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1340
Points
5
Maybe the button is not pushing the internal button properly. Undo the back and remove the watch unit from it's case and then see if it works when you press the internal button.
1helpful
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
1helpful
Nike Triax Fury works after replacing battery, but buttons wont work or change anything!
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Good luck.aa07e646-2c11-45e3-b8fa-b40ec2fd82c2.jpg
3answers
When i changed the battery the watch says error so cannot set time battery lite flash on of recall button seems not to be all the way out out watch is lance 4 thanks
hi,
Press and hold 4 buttons on the four corners at the same time for 3 seconds to reset the watch after battrey replacement. check the last page of the manual for the same.
http://www.nike.com/timing/extranet/product/os_alticomp/osac_manual_eng.pdf
If it doesn't help then try another new battrey.
OK
I have an Nike Alpha project watch that's around 10 years old but don't know where the manual is. The watch has the following modes: TIME, CRON, DATA, TIMR, CNTR, ALRM I'm trying to find out if I can set...
Not too difficult. Press BL (bottom left) to go to TIMR. Then TR to confirm. Then TL and hold until it "confirms". Then in "Seg 1" press BR to move to minutes. Press TR to adjust to 10 Press TF to accept Press BR to move to Seg 2 Press TL and hold until it confirms. Press BR to move to minutes. Press TR to change to 1 Press TF to confirm. You can set up more segments like this.
46helpful
Trying to set time on nike watch
1. Press the bottom left button(MODE) to put on Time mode.
2. Press the LIGHT button (ADJUST/LIGHT) for three seconds.
3. Press the MODE button to select what you wanna change, be it hours, minutes, or seconds.
4. The upper right button (START/LAP) is to move a number up, the bottom right button (STOP/RESET) is to move a number down.
5. Press the LIGHT button to finish.
4helpful
3answers
I dont know how to set the time
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
Nike watch problem
Okay, mine's a Chisel but I'm pretty sure the module is similar, if not the same, across the Mettle range.
Anyway, press and hold the light button - marked adjust - until the display says "hold to adjust"; after a couple of seconds the time display will return and the hours will be flashing.
To adjust up, press "start/+" and down press "stop/-". To cycle through the options, press "mode".
Once you're done, press the "adjust" button again to return to regular timekeeping mode.
Enjoy your Sledge - if you don't I'll have it!!
Regards,
Martin.
4helpful
How to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
Mar 09, 2008 • Watches
26helpful
3answers
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
15helpful
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
