1998 Acura CL Logo
Posted on Aug 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 98 acura cl it wont start ,not a sound , battery is good and starter is good, what can it be. I think it might be a relay or something cause the lights work fine but the windows wont roll down.
Anonymous
Level 2:
  • Expert 211 Answers
  • Posted on Aug 02, 2010
Anonymous
Expert
Level 2:
Answers
211
Questions
0
Helped
87408
Points
495
Battery might have enough juice to crank but still has enogh for small lodes like lights.will it jump off or still nothing .if it jumps off drive it straight to the auto parts store , auto zone, advanced auto etc have them check to find out if battery or altenator, if it wont jump look for lose connetions to starter starters can abruptly **** out .especialy if you drive threw alot of big pudles if you pull the starter they can check it for free also
Would a defective ignition relay cause it not to start with the key?
ignition relay could be your problem. Owners manual should show you location of the relay, usually under the hood.
2001 acura cl type s wont start, just clicks
Tap on starter while someone holds key in start position. Check negative battery cable. Make sure battery good, terminals clean and tight.
1helpful
3answers
My acura cl 3.0 1998 wont start change the battery hear clicking noise in starter but just replaced it back in may pf this year.
The clicking noise is the starter relay, which sends power to the starter. sometimes the relay is mounted on the starter, sometimes on the fender. I would say the starter is bad and needs replaced. Sometimes you can get a bad starter from the factory. Just because its not that old, or even brand new, doesn't mean that its a good working starter. Replace that starter.
I have an Acura Cl 3.0 1999. It has drove fine sick I bought it a year ago. I drove to the gas station turned it off, filled up with gas, went to turn it back on and nothing. Only sound is two clicks from...
if it dont crank how would you say the starter is good.
you dont know that. sorry'
making assumptions is the top killer of all diagnosis.
you set in driver seat:
i key on, is the CEL ,charge and BRAKE lamps glowing
if not you lost all power ,12vdc to dash and ignition.
they must glow, if not the battery is drained or a fuse is blow.
check all fuses , now.
if all those normal lamps glow, (warnings) per the operator guide.
the good, you have 12v power.
proceed to cranking..
"as they say, Call the Auto Club time"
the first check, is called a jumper cable jump start off a running car.
if that works, then the starter is good and the battery was ONLY discharged. (no assumptions. see?)
then and only then could you say, starter is good. see?
if the car JUMP passes ,then battery bad or charge system failure....
(ask for help that topic, "my battery is drained, why?"
if the JUMP fails (to other cars battery)
we then hot wire the starter, does starter crank fast and robustly>>?
yes?, then the key line is bad.
no ?, then the starter is bad. or its 2 huge cables are bad.
YES?? starter hot wires good. then? !!!!
see the tricks here,
my guess is this car is A/T tranny, Automatic.
http://www.fixkick.com/nocrank.html#tricks
this page also teaches , hotwiring any starter , safely.
Ac clutch relay fuse has no power 98 acura cl
On this website fuse box diagram and description for Acura CL (1997 - 1998)
Acura CL 1997 1998 wiring diagrams fuse panel
Where is the fuse box in a 98 acura 2.3 CL? My brake lights not working and im thinking it may be a fuse
Most cars are under the hood by the battery in a black box. Also check relays
1helpful
My 93 acura legend wont start. Ticking sound??
That sounds like a dead battery. The ticking sound is the relay (a type of switch) which enables power to the starter motor when you turn the key. If the battery is weak, the relay will click, but there is not enough power to turn the starter motor.
Car wont start got a starter but its the relay switch
STARTER RELAY IS UNDER THE HOOD AND UNDER THE DASH.IT COULD BE THE STARTER SOLENOID ON STARTER BAD.IT WILL CAUSE NO CRANKING PROBLEMS.
2answers
Neeed to find out where the startr relay switch is
who is they??what exactly is your problem??? there is a starter cut relay under the dash to the right of the steering column, behind the knee bolster/lower dash cover. 4 wires, black/green, white/red, green, black/white. its hard to diagnose a problem if I dont know what you are trying to fix.
My car wont start
Try unhooking the battery for about 20 minutes, this resets the computer
Top Acura Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Acura Expert? Answer questions, earn points and help others
