Every time I plug in my bunn coffee maker, it trips the GFI. But when I plug it into another plug in my kitchen, it will work, but it seems like the water reserve is not right. It blows too much steam and the top starts lifting up from the pressure of the steam, then it starts leaking out the top left side. Then if I pour enough water to make 10 cups, it only makes 6 or 8. The coffee maker is only 3 years old, what should I do?
That's crazy I pay a 145.00 every 4-5 years for a new maker, my g/f has had a competitive brand 15 years no problems
Sounds like a heating element is touching some metal part inside the unit,the element is located under the warmer plate,if you can remove the base(if its not rivited on) you can isolate this element to see if this is your problem
SOURCE: Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
SOURCE: GFi breaker blows
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
