Watches Logo
Posted on Aug 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A Casio Illuminator watch a few years old. How to set month, How to set 12/24 hour time?
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Aug 01, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291846
Points
7081
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Making an hourly beep
From memory you either press the A + C buttons at the same time or it will give you the option to turn it off during the time setting function. Most Casio instructions are available online through Casio
15helpful
Can not change from 24 hours mode to 12 hours mode on CASIO DW9052-1B
1. Press [A], the top left button, and the seconds should start flashing 2. Once you have some digits flashing, press [D], bottom middle button, and will switch between the 12h/24h formats 3. Wait a few seconds and the digits should stop flashing and return from the time set mode, to timekeeping mode.
Here is a link to a manual directly from Casio, showing you all of these steps. As per the explanation on top of the manual, this should work with 3 different models of Casio watches, including yours. http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1659.pdf
Have a good day
2helpful
I can set the digital readings but not the common watch hands, how do i set the hour hands?
watches;
Accept terms
3helpful
How do i set the time and the alarm?
click the mode button 3 times and hold the adjust button until it gives you an option to change you change it by using the mode button to choose min.s or hours and the time memo button to go down in time and the receive button to go up in time and then click adjust to set it then you just click the time memo button to turn it on and off a few lines on the top right corner should tell you if it is on or off.
How do you move the time up 1 hour on a casio illuminator
http://world.casio.com/wat/download/en/manual/
There are so many aplications use of the manual will be manditory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
5helpful
Change annalog time Casio illuminator
Hope this tip helps.
R/
David
7helpful
3answers
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
