Don't worry this caused because of two reasons
1)flipdown application might be corrupted or
2)You would have installed some virus in the name of flipdown .
Due to these two reason the phone is behaving like this
First try this:
1)Click the MENU button continuously now you can see the application running behind the screen.select all the application and close it.and go to menu->application->application manager delete the flipdown application.
2)Your not even able to do any thing you have to reset the phone
Hard reset code is type *#7370#
default code is 12345 unless your network provider has changed.If it is changed you have to call him and ask him about the code.
Note:If your phone is not willing to start up.you can try this.:
Press these buttons simultaneously for hard reset.
on/off + * + 3
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
The phone has hung up because there are some errors in the installed software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
