Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
Posted on Sep 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Old outboard ground wire melting
Hi. we got a old minn kota engine and a guardian deep cycle battery 12v. we gt a charger and charged it over night and it looked fine. went out today for the first time, attaching it to our metal rowboat and after about 3 minutes full speed, about 1 mile per hour we smelt burning ruber and saw smoke and a melted ground wire, still works but it cant be good. help please
Steve P
Level 3:
  • Minn Kota Master 3,912 Answers
  • Posted on Sep 12, 2017
Steve P
Minn Kota Master
Level 3:
Answers
3912
Questions
5
Helped
1307721
Points
15904
1. Short in the trolling motor itself
2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!!
3. Bad/dirty/corroded battery connections
..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
2 Related Answers
Anonymous
  • Posted on Jul 17, 2009
SOURCE: what size battery does a minn kota 565 5 speed
12 Volt
bigcass
Josh
  • 35 Answers
  • Posted on Jan 19, 2010
SOURCE: is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
I have a Minn Kota 315D 3 bank charger. When I plug it in to my electrical outlet only bank 1 shows a solid yellow light. I am not getting power to bank 2 and 3.
A solid yellow light on Bank 1 of your Minn Kota 315D 3 bank charger indicates that the charger is in "float" mode, which means it is maintaining the battery's charge at a safe level. It sounds like there may be an issue with the connections or wiring for Banks 2 and 3, preventing them from receiving power.
Here are a few things you can try:
  • Check the connections between the charger and the batteries for Banks 2 and 3 to ensure they are tight and secure.
  • Ensure that the circuit breaker for the charger is not tripped.
  • Check the wiring for Banks 2 and 3 for any visible damage or corrosion.
  • Ensure that the batteries for Banks 2 and 3 are not in a low state of charge or are not faulty.
  • Try to reset the charger by unplugging it from the power source and plug it back in after a few minutes.
What sizebattery is recommended for a Minn Kota RT40/s riptide motor
Hi, you can get away with a 70 amp hour deep cycle battery but I generally fit a 100 amp hour deep cycle battery. Hope this helps, regards Phil.
My brother inlaw got a minkota 40ta all terraine trolling motor that is supposed to produce 40 pounds of thrust. it does not seem to produce even close to that. is it possible that the motor is turning the...
I would check the battery. If you're using an old or under charged battery you will loose power for sure. Make sure you're also using a 12v deep cycle marine battery as this will ensure proper operation and a longer battery life.
Wiring diagram for a minn kota mk220 2 bank charger
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals.
The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
2answers
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
What size batteries needed for minn kota 24 volt 74lb thrust
I use Red Hot Mama batteries. These have held up for longer than any other brands that I have used. These are deep cycle marine wet ones.
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
