simple to fix up your self please follow this instruction below
Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
Step 2
Set the clock by pressing the "Clock" button.
Step 3
Turning
the dial on the sensor microwave oven will display the hour of the
day. Once you have found the correct hour, press the dial in.
Step 4
Again,
turn the dial to set the minutes of the day. When this is completed,
you will need to press the dial in again on the sensor microwave
oven.
Step 5
When
the time and minutes are set, turn the dial again for a.m. or p.m. Then
you will need to press the dial in to save the settings.
Step 6
Press the "Start" button to allow the clock to begin on the sensor microwave oven.
On some Galanz models setting the clock is a bit unusual. You have to press the clock/preset button once then press pause/clear. Now it is in Clock mode setting and you can set the hour then press clock/preset again to set the minutes then press once more clock/prest to finish the operation.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
Did you try pushing the clock button, setting the time (eg. 300) for three o'clock, and then push the clock button once more. If this doesn't work, don't push the clock button at the end. Just set it, and let it stay until it stops blinking - and then it should be set. If you need further assistance, let me know and I'll help you. I'm just going by the usual standard of setting clocks on microwave's - but maybe with this model, there's another way. Good Luck to you! - Jim
1. If you press the 'Delay Start' button, the time display will go blank. 2. Now enter the correct time, using the 'Minutes' buttons to set the hour, and the 'Seconds' buttons to set the minute. 3. Now press 'Clock' 4. Sorted!
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
After setting the time push the clock button again and it should start working after a minute passes (on some models you have to hit the start button after setting thr time!
Please rate this response
thank you!
