E2 Code indicates a Sensor Error automatic shutdown. To find out which sensor it is you will have to call Haier Customer Support
1-877-337-363.
In the meantime, turn the unit OFF & unplug it for 15 minutes. Then plug the unit back in and turn ON. ON. Hopefully the unit reset itself and reverted back to the original factory settings. And you can set te humidity extraction level where you desire. If the error code reappears, definitely contact Haier, as youtr unit is still under warranty.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Hi, Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
Hi, The E-2 code is similar to the E-1 Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Hi!
You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
E1 means one of the buttons on the touchpad is pressed in. The remote will still operate the unit. You might have to pull the panel of, and check all the buttons. If all seems fine replace the control board. might not be worth it thou..
