Question about Ruud UBHC Air Conditioner
RUUD AC cycles warm & cold 24/7
Hello I have a ruud central ac which I bought in 2005. The compressor was chg'd 2 yrs ago under warrenty. Lately I notice that for quite a few hours during the day the air blows warm, then suddenly it will blow cold again. Repeat, repeat, repeat. It is a pattern or cycle of warm then cold. I originally thought it was blowing warm due to it being the hottest part of the day. But that's not right b/c it blows warm in the middle of the night too.I have it set at 77 but the temp inside can go as high as 84 during a warm 'cycle'.I have a digital thermostat that is 6 yrs old. Filter is chg'd every 30 dys. What do you think the problem is? I have someone coming to look at it in a few days & don't want to be taken for a ride.Thx----Mrs. Cornwall
  • 455 Answers
Hello Anna Sounds like the compressor is overheating and stoping on overload internally.Then it cools down restarts and runs into overload again.I would like to see the freon pressures when running.Could have a clog/restriction in piping.I dont like that you went thru a compressor already, the original installition is suspect.The original (1st) failure cause must be corrected.Check the TXV valve replace, filter/dryer look for a kinked pipe are ideas for overheating.Make sure condenser coil is free (ari flow)& clean also.
Posted on Jul 31, 2010
6ya staff
SOURCE:
I have a 2 ton central unit for my upstairs. It is 25 years old and still runing. Lately it will run all day when the outside heat is peaked and then when dark falls it will catch up at about 10:00pm and...
Hello, it could be that the unit is slightly undercharged and has a small leak. Usually when the cooling is needed the most the ac wont be able to keep up with the heat load as you mentioned.
Jul 15, 2011 | Ruud UAPA042 Air Conditioner
Ruud furnance/ac central air
i can help u but mikep858 i need u to give me the model of this ac okay the correct one
best regards
Aug 14, 2008 | Ruud Central System Air Conditioner
"RUUD Achiever 90 Plus" Propane
Hello bikejocky,
MOST LIKELY you have a "hot surface" element
with a tiny crack in it...
About 25 years ago... I put one of my poor abused
fingers on the element to see if it was at all warm...
In so doing I touched the spot where the crack was...
and it did INDEED have a full 120 volt, 60 cycle AC
current waiting for my FINGER to complete the
circuit... (not a recommended procedure)
My 25 year old RHEEM... finally kicked it.
I keep spares... and bought 2 more when I used
the last
Since these parts are pretty cheap... I get spares
62 22868 93 Rheem 62 22868 93 Hot Surface Ignitor
Take a look... There are two basic configurations
The WISEST APPROACH is to use a "meter"
to verify the "line current" is present (not finger)
and check the "SURFACE" for continuity.
Once you copy the number DIRECTLY from
YOUR OWN part... look it up... internet... eBay
and AMAZON (like Robert Shaw #41-408).
http://www.ebay.com/itm/ROBERTSHAW-41-408-Hot-surface-ignitor-NORTON-271N-/121727955205?hash=item1c578d3105:m:mJR3I8e9mTI60A-dtmvdVrw
>> It is the plug & mount that is important...!!
(consider that spare you always wanted
(If you get it... you will probably never need it)).
The cycling limit & fan
(never touched a RUUD... (so... I presume)) is to clear accumulated GAS FUMES to avoid any explosive
situations.
I do know RHEEM... (ERGO... I have every confidence)
((RHEEM & RUUD, in my opinion, are design twins)).
Carnac the Magnificent
May 10, 2017 | Ruud UBHC Air Conditioner
My Ruud AC unit compresssor is creating a lot of condensation and home is not properly cooling.
check ur coils are they dirty how is your filter on hot days it will condensate alot however a unit is desighned to opperate for an average of around 87 degree day and may need the superheat adjusted. check and make sure the bigger line coming off that unit is very cold hold your hand over the outdoor fan is the heat off it very warm
Sep 11, 2010 | Ruud Central System Air Conditioner
My adp coil already failed in my only 2.5 yr. Old Carrier ac unit. I am now looking at an estimated $1500.00 repair. Coil is under warranty so the above cost reflects labor only. Adp serial #7107A07780....
Sorry, I don't have any solution but I'm in the process of replacing my 2 AC systems (4 tons by York). My RUUD dealer has provided RUUD ac and gas furnace with ADP coil and not using RUUD coil. Should I insist on using RUUD coil rather than ADP coil?
Thanks,
Jun 30, 2010 | Heating & Cooling
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
2.5 RUUD AC not working, power must be getting to the unit.
Have them turn the outdoor unit off and wait a few minutes. When they turn it back on they should here
the fan and the compressor come on. They are to different sounds.
If they think that they have both come on, tell them to check the black insulated suction line. it should at least cold to the touch. If not it could be a freon issue.
If the line does get cold, have them checkthe filter in the house. If that is ok tell them to turn the power off
to the outside unit. Take a garden hose and wash
the outside coils on the outdoor unit,be carefull not to
smash the fins. Wash them at an angle from top to bottom.
Jul 05, 2010 | Ruud Central System Air Conditioner
Could you diffrentiate LG and RUUDE make for me
I have seen much more Ruude products out there. LG must be a lower end brand. Lg also makes smaller air conditioners
Jan 29, 2008 | Ruud Central System Air Conditioner
Ruud UBHC Air Conditioner Logo
152 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
