Video Cameras Logo
Posted on May 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Missing codec - how to view asf files on windows
We have problems with files recorded on a panasonic digital camera. We can only downalod them in asf format, and then cant play them as the codec is missing.
Would really appreciate it if someone could advise how to convert asf to wmv/avi/mpeg. Or explain where i get the missing codec and install it.
It is my parents camera, and they desperatly want to download the videos they have taken of the grandchildren.(Panasonic DVC NV-GS55)
Many thanks in advance
Nanny
Level 3:
Genius:
  • Panasonic Master 2,351 Answers
  • Posted on Nov 20, 2019
Nanny
Panasonic Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989345
Points
7262
If you ever have trouble to play ASF video file on the computer, you can turn to ASF video player for help. Leawo Blu-ray Player is a 100% free software. Arming your Windows computer with this program will guarantee all your ASF files are supported. Besides being as the best ASF player for Windows 7, the Windows version is also available on Windows XP/Vista/8/8.1/10, etc.
3 Related Answers
Anonymous
  • 18 Answers
  • Posted on Jan 01, 2010
SOURCE: i cant eject my Panasonic NV-GS55 Mini DV Digital video cassette
Try ejecting cassette whilst powered from AC Adaptor. Secondly, try operating Eject from powered off mode. If operation LED starts flashing after any of these attempts, the mechanism is probably jammed or has become mis-timed. Unfortunately this requires professional intervention to avoid further damage to your equipment.
I hope this information is of assistance!
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Sep 05, 2010
SOURCE: I want to connect my
for downloading pictures only ..you can use the usb cable ..but first you have to install the usb driver that was provided with the camera
Run the driver ..and connect the camera when it asks for it ..Be sure you use teh camera plugged into the adapter ..cause any battery power lost ..can cause the card beying erazed during the transfer ..so use it plugged into the cord when downloading ....
For to download the videos you have to use the fire-wire cable ..and the manager that was provided...to be sure that the camera is seen on the computer ..you need all drivers installed (including for the fire-wire ..and this have to be enabled) ..
the easy way to download video is to transfer them on the card via the editing mode n the camera ..and get them from it with a card reader..
Here is a mode to import with the fire-wire cable using the windows movie maker...from a tape ..video..
http://www.5min.com/Video/Windows-Movie-Maker---import-from-a-DV-tape-6876
Anonymous
  • Posted on Sep 25, 2011
SOURCE: How do I reset the
howto change mpeg to jpeg
2answers
1helpful
Can't play the videos I've recorded...
The panasonic vidoe are in quicktime - you will need to either download quicktime software to run the vidoe clips or you can convert the file format from quicktime into windows media player format. The codecs you are downloading may convert your files but I am not familiar with GO.
I suggest you download quicktime for now, so you can at least play your vidoes. be sure to check your operating system for the download.
http://www.apple.com/quicktime/download/
At a later date, you may or may not want to edit them in which case you can download a conversion tool or do so online.
2answers
Video transfer to Camera
possible that Aiptek requires a special "header" section (inside file code) of said file to allow view on device...but just a guess
2answers
S-SNAP AV100 Unable to open movie files on my pc.
MOD files should be viewable using MediaPlayer. I know at least with version 11. There's some chance though that you will need the codec, but don't you have this in the software CD supplied with the camera? If the camera transfers in MOD most chances that it's the best format to transfer on. Later you can convert it probably if you want. Good luck
Folders come up on my screen
The data on the SD Memory Card can be broken up into five separate folders (where applicable): [DCIM]: The images in this folder (e.g. IMGA0001.JPG) are recorded in the JPEG format. [MISC]: Files in which DPOF Data has been set to the image are in this folder. Slide show data created by SD-MovieStage Ver. 2.5 are also stored in this folder (e.g. AUTPLY0.MRK). [SD_AUDIO]: Stores music data files (e.g. AOB001.SA1) recorded by the SD-Jukebox Ver.4. [SD_VIDEO]: MPEG4 moving pictures are recorded in ASF format (e.g. MOL001.ASF). It can be played back with Windows Media Player 6.4 or later. [SD_VOICE]: Folder in which voice data files (e.g. MOB001.VM1) are stored.
1helpful
SD Memory Card
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
