Canon imageRUNNER 2270 Copier Logo
Tee Cee Posted on Jul 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My copier machine is printing out black lines.
Cannon Image Runner 2270
My copier machine is printing out black lines. There is a new toner cartridge in there. Is there something else that I would need to do in order to get it stop printing black lines across my doucments? Also is there a manual on line that I learn how to do a configuration report about my printer maybe I have to purchase a maintenance kit or new drums?
Anonymous
Level 3:
  • Master 1,219 Answers
  • Posted on Jul 31, 2010
Anonymous
Master
Level 3:
Answers
1219
Questions
Helped
673820
Points
2880
Hi, does stripes appears only on copies or also on printed images?
If only on copies that means that you have to clean the copy glass.
If on both, its probably drum unit that causes the problem. Usually the stripes are slim, and verry close to each other, like a sharp brush paint job.
How many copies do you have with these drum? check it on 123 button.
If the copie is on one side totally black and the toner isnt fixed on paper that means that you have to replace fixing film.
For service manual write me on [email protected].
Hope that helped!
Asaad Gerges
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Mar 02, 2015
Asaad Gerges
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
10717
Points
5
The lines in the printed copies in the IR2270 happen only when
1-faulty in cleaning blade either in the developing unit or drum we call it bad cleaning in this case you need specialist to fix it.
2-drum life time is over in this case you need a new drum unit
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Printer has all full cartridges, not printing clearly
Does this machine have drum units, image units and toner units? what combination? Replacing the toner cartridge will not fix the issue with the drum or image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
On my Cannon runner 5570/6570 why my printing jobs come out too light?
If it's a reconditioned toner cartridge.. Then it's fine. It won't be as original cartridge ink.
If new check setting there will be option - Save Toner, unselect this option
Konica Minolta Bizhub c754e Blue Lines after installing new machine
The blue toner cartridge or drum are damaged. First, try a different toner cartridge. This will probably eliminate the lines.
1helpful
Quilt y of print !, it gives double printing on page one is print of original doc.& second as its image what should i do to improve its print quilt y. i will be thank full to you
Dots, Lines, shadows and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots. Double printing is also due to the deteriorating cartridge. The drum is not getting clean after its each rotation and hence the remaining toner/ image is transferred to the paper resulting in double printing. So, it is recommended that clean the drum etc (this would help temporarily). Also, make sure that the toner cartridge is in good working condition. If not you may replace the cartridge.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
We need to replaced our toner at cannon image runner 5020?
just open the cover on the rigth side near the control panel display then install the toner cartridge
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
Cannon copier image runner 1670f
the machine have toner,can you print a document.replace toner
old marine
old marine
ZJ Limited
ZJ Limited
