2000 Mercedes-Benz S-Class Logo
Posted on Jul 30, 2010
2000 s500 will not start,but key turn
2000 s500 benz will not start,but key turn but no crank
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Jul 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
7206
Points
68
Next time you try to start the car just put the key in and turn the ignition on dont try to start it to see if your security light comes on. if any kind of security light come on or flashes call a dealer to find out how to reset the system. if u have the wireless transponder for the security the battery may have gone dead
My 2000 S500 mercedes will not start. the key turns but the engine will not crank. it has a new battery
Does it click or do anything? If not, then the plastic gears inside the ignition that control the vehicles ACC and ON positions along with the cranking may have slipped. Have someone to pull the ignition switch panel and check and make sure the "gears" are working properly.
1998S 500 battery dead for a month now car cranks does not start sounds like it's going to start but doesn't
listen for the fuel pump when you first turn the key if you don^t hear it ? start there .
Car wants to but won't start, Battery in key is
Well try changing the battery and see if that helps your situation, if not then id start with a full tune up and go from there. Im sure a new fuel filter wouldent hurt either.
1helpful
I own a 2001 s500 mercedes benz. I put my key in the ignition and tried to turn it but it would'nt turn. What could be the problem/?
Steering wheel is 'locked' - move it left or right while trying the key. Or make sure the gear selector is fully in Park, if an Automatic.
My 2000 Mercedes Benz S500 is dead- electronic key does not
It's not that unusual for a battery to fail that soon, and the "no lights, no nothing" says that it's the battery again. Your best bet at this point is to pull the battery and take it to the point of purchase for testing. They should either replace it under warranty or charge it for you. After you replace the battery you should have the charging/electrical system checked for possible shorts or power drains.
BillB
My 2000 s500 won't start in cold winter season. i
Malfunctioning fuel system.
Fuel injector[s] leaking...check fuel pressure,more then 53psi
check fuel injector resistance / ohms/
Ignition component damp or demaged.Checks wires broken,loose or disconnected in the starting circuit.Worn, faulty spark plugs.....
3helpful
Merces Benz s500, Ignition key does not turn, can
Check Battery in car(make sure is not weak or dying), check battery in remote fob, possiable draw in system possiable fuse or possiable keyless entry module failure
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
