Question about Pyramid (Ns 12) 12 Amp Noise Suppressor
How to install in-line noise suppressor
I have a in-line noise suppressor for my car but i dont know if i hook it up to my battery or my alternator.
  • 58 Answers
This type of filter goes in line with the power for your radio. Cut the wire you are using for your power the red wire on your filter is the input the blue wire should go to the power for your stereo and ground your filter and thats it.
Posted on Jul 30, 2010
SOURCE:
HOW DO I HOOK UP A NOISE SUPPRESSOR WITH THREE WIRES COMING OUT OF IT. WHEN I HOOK UP THE BLUE WIRE THE AMPS STAY ON. THEY SHOULD GO OFF BUT THEY DON T.
The blue wire from the stereo is for something else, like a retracting antenna. So don't connect the blue wire there. The Blue wire of the suppressor is the 'new' Red hot wire that connects to the red wire (12 volts input) of the stereo.
Dec 28, 2014 | Cars & Trucks
START MY CORVETTE AFTER I PLAYED WITH THE RADIO TO LONG
The battery is flat? You can get a jump start if you know someone with long battery leads (use the type with a voltage surge suppressor in-line). Alternatively buy a small battery charger and hook that up overnight (they are inexpensive)
BTW if you drive a Corvette you really should have a battery charger (just joking here)
Oct 17, 2014 | Cars & Trucks
Where in the line up should a Boss Noise Suppressor Pedal be placed on a pedal board for maximum effect ?
since you talk about a lineup, which causes noise , you put him apter your lineup and before your amp
Oct 01, 2014 | Boss NS-2 Noise Suppressor Pedal Noise...
Can moving the noise suppressor from the distributor cause any problems ?
Won't cause any issues as long as it is hooked up and it also is grounded well. Many fords put them on the upper intake, right at the front of the motor.
Mar 17, 2013 | 1997 Toyota Celica
The cart wont click over dont know anything bout cars so i need to find out if my starter or my alternator went out and sure my battery i need a new one because the car used to click over till we hooked up...
First if the jumper cables were hooked up backwards you could have killed your battery, which was probably dead to begin with. Get a new one then try and start. If it doesnt look more into the ignition switch than the starter. Alternator has nothing to do with starting, it could be bad and not charging the battery but will not cause your car not to start.
Aug 02, 2011 | 1998 Oldsmobile Intrigue
NS50 noise suppressor, schematics aren't clear. on my radio, I have a red wire going to the ignition and and orange to constant power. do I conect the noise supressor to the red or orange? does the black...
Noise suppressor should connect to ignition and black wire to chassis (metal body) of car, this is electrically the same as neg. pole of battery which is the same as ground.
Apr 08, 2009 | Pyramid Ns50 35 Amp Noise Suppressor
Dash speaker
Sounds like you need to install a noise suppressor,go to radio shack ,buy a noise suppressor and install it in the power line that feeds the radio, connect it between the radio power line and the power feed from the car. good luck and please rate this answer,thanks.
Apr 08, 2009 | Car Audio & Video
Electrical popping noise,thru. speakers on startup
the alternator can make the popping sound through the voltage, some radios need a suppressor fitting to them. on the power lines, you can get then to go on the alternator if the alternator is still giving out the right voltage, it could be the suppressor in the alternator has gone, can make light go dim and bright on revs.
Jun 09, 2017 | 2007 Cadillac CTS 3.6L
Alternators
It's not your alternator, why would that cause your lights to flicker as it goes through the battery FIRST (read: it's a giant power filter/surge suppressor)?
A Nippondenso alternator should last for about 10 years or 150K miles or so, unless you are driving 100K miles a months, stop replacing the alternator.
What does the noise sound like?  I think you have a serpentine belt,  is that correct?
Nov 05, 2008 | 2002 Honda Civic
Pyramid (Ns 12) 12 Amp Noise Suppressor Logo
4,498 people viewed this question
Top Pyramid Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ALPHANSO TAYLOR
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
