There is no such service code to match these two ICs. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Search the site by type in either the "brand name" or the "Ic number used" in your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
This is not the fault with the Main IC. Check all other components connected with it. Check the oscillator crystal. Check the settings in it service mode. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. http://electronicshelponline.blogspot.com/ Service mode details to many popular brand TVs are given in detail. Check the site with patience.
To know, how to enter its service mode, by using remote control, check this link. http://electronicshelponline.blogspot.com/ It has details to get into service mode to many brand TVs. Pull up previous posts there, either by its left side bar, or, view it in 'Timeslide' option.
Either bad solder connections on the vertical output IC or bad part in that circuit, IC or something else. I presume it is NOT a flat panel set but has a picture tube as no model number is listed.
You need to use Aiwa Service Remote to enter in service mode and adjust service data for red and Blue drive of CRT. Do you have that remote and service data reference book of Aiwa tv ?
