SOURCE: Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
SOURCE: how do I remove the towel bar from the wall?
on both ends look underneath and there is a tiny hole with an Allen/hex head insert u turn counterclockwise wise and loosen srew until you can tilt end upwards towards the wall, reverse to install
SOURCE: My Brantford towel bar is loose. How do I remove
There are some tiny screws under the posts. Loosen them and lift the post off of its mount.
