KitchenAid K45SS Classic Stand Mixer Logo
Posted on Apr 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mixer not creaming butter and sugar...
My bew mixer does not work well at making a simple cake mixture.. what am I doing wrong? I use the beater as indicated in the manual, but it is not beating well..
CJ C
Level 2:
Scholar:
  • Expert 66 Answers
  • Posted on May 09, 2008
CJ C
Expert
Level 2:
Scholar:
Answers
66
Questions
0
Helped
45568
Points
113
Make sure you are using the right attachment. usually for batters you want to use the flat beater. not the dough hook. the flat beater looks like a triangle with lines through the center. and make sure you are using the correct speed on the mixer. start out at stir and then go up to no more than half speed. these mixers take a little longer to incorperate batters but they do a very good job at it. if the batter is thin enough you can try using the wisk as well. but only if it is a thin batter.
Mixer Kenwood Chef too high, tried adj screw
I put an extra plastic circle in the base of my machine as well as doing the adjustment and it worked.
Hi my mixer suddenly stopped when i was working on it. The butter i was beating was kinda hard is that a reason it stopped?
Does the mixer not turn on at all or the beater just wont turn? Depending on the mixer it could have a fuse that shuts the mixer off if over heated, but it could also be gears.
If you can get the model off of the bottom of the mixer, and then give a bit more information on how it is not working then we can help you with the repair.
Also yes, the butter would most likely be the reason the mixer stopped working. You are supposed to use butter that is soft & at room temperature. I find that if you are in a rush or forgot to soften the butter you can cut it up into small slices and then cream it in your mixer and it doesn't strip the gears.
-Colleen@MendingShed
Apr 16, 2015 • Food Mixers
K45 kitchenaid mixer quits working under load? When beating egg whites it works great but try to cream butter and the beater stops.
It will be a broken or missing pin through a gear or the planetary or something wrong with the fuse gear. It should be easy enough to find but you will need to split the gearbox cases to check.
Beater on Kitchen Aid stand mixer doesn't touch bottom of bowl
Why would you raise the beater if you want it to reach the bottom of the bowl? You need to lower the beater. Turn the screw in until it just touches with empty bowl on high speed then turn it counter clockwise a 1/4 turn so it will just clear.
I have a new kitchenaid mixer and both times i've used it the cake did'nt come out right, it was bland and it fell apart and that never happened before. what did I do wrong?
It could be that your over mixing the batter. It is very easy with a KitchenAid to push a batter too far, and you get too much air, or cream the butter too much into the flour, or press all the oil out of peanut butter. Try using the mixer for only as much to get the matter mixed.
1helpful
I just got my mixer a few weeks ago for Christmas. I have made cookies twice. My problem is that the bottom of the bowl doesn't get scraped. The first time, I ended up putting more flour in the dough...
Put the flat beater on and mount the bowl to the machine. Now look for the screw next to where the beater mounts on the head- this is the adjusting screw. Turn it counterclockwise to lower the beater, just a quarter of a turn, and then check where it's running in the bowl. Repeat as necessary. If you need to raise the beater, just turn the screw the other way.
lp
I was making a standard cake with my kitchenaid and in the middle of creaming butter and sugar together, it stopped working. Turned it off, switched plugs, let it cool down, etc - it won't turn on now and...
either the electrical motor brushes are worn down on the motors commutator and can no longer contact the motors commutator bands,or if its a newer style mixer the triac that controls the speeds on the unit could have opened up and can no longer supply variable or even high speeds
8helpful
Kenwood Chef model A901 smoke & burning electric smell from motor
there is a kit on ebay for both 701 and 901 kenwoods requires use of soldering iron do a search for Kenwood motor repair it is unlikely to be the motor usually the speed contoller components
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
