Question about MTX (SLH-T7512X2-A) Car Speaker
My subwoofer will not work at all!!!
I have two MTX Audio Thunder 5500 12" Subwoofers that will not work period. Hook it up and absolutely nothing happens. No pop, no noise, no distortion, nothing! Could it be the voice coils or am i just completely out of luck??
  • 1,498 Answers
Actually, you could be in luck.
If you are getting 'absolutely nothing', it could be something simple. Open it up (carefully) and make sure the wires are secure on both the speaker and the inner connection leads.
I've come across several this has happened to that were brand new.
Good luck
Mike
Posted on Jul 29, 2010
SOURCE:
How many watts will the 10 inch mtx thunder 4000 have
It should tell you on the back of the sub ,The continus watts it will handle, If not phone the place you got it from, Or some place that sells them,
Nov 28, 2012 | MTX Thunder 4500 T4510-04 Car Subwoofer
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
I have two 12" subwoofers
There are a couple of problems it could be. First, swap the sub to the other channel to see if it's the sub or the amp. This will get you started. If it's the sub, it will need to be replaced. If it's the amp, repost and we will try to find the problem together.
Aug 27, 2011 | MTX Road Thunder RT12-44 Car Subwoofer
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
What is best way to wire 2 mtx thunder 4500's to a kenwood kac-7205? thanks! james
I would hook up the subs in parallel set up. Lower the resistance causes the amp to create more power to the amp. Your amp can handle 2 ohm load so from my stand point it is best to set up this way. Here is the link that displays how to set up subs:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Feb 12, 2011 | MTX Thunder 4500 T4510-04 Car Subwoofer
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
My friend sold me his subs today and one sub doesn't work. they're mtx thunder 8000 will mtx fix the sub for me?
They probally would, but i just found that sub for 51.00 im sure it would cost that and more to have.it fixed
Nov 09, 2009 | MTX Thunder 8000 T8104 Car Subwoofer
MTX (SLH-T7512X2-A) Car Speaker Logo
193 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Philip Armitage
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
