I can't say I'm sure on this but almost all vehicles that have locking fuel doors have a release cable inside the trunk near where the door is located. May be behind the trunk liner material in that general area. If you have your owners manual it should have a description of the fuel door operation in it somewhere along with how to open it should the normal system fail. Good luck and hope this helps!
The fuel filter is serviced only as part of the left fuel level sensor assembly in the fuel tank
1. Remove rear seat bench
2. Fold carpet forwards
3. Fold back rubber mat
4. Remove the nuts and fold back metal cover
5. Disconnect electrical connector
6. Release and disconnect fuel feed and return lines
CAUTION: The fuel gauge must roughly indicate zero before the left tank opening is opened. Large quantities of fuel may emerge upon opening. If necessary, keep the left tank opening closed and feed an extraction hose through the right service opening to the left tank half and drain the fuel out of the left tank area before proceeding.
7. Release the screw cap
8. Carefully raise fuel level sensor until sensor flange emerges.
CAUTION: Risk of breakage! When raising sensor unit, do not pull excessively on connecting piece of fuel return line.
9. Disconnect line to fuel filter
10. Disconnect suction jet pump from fuel filter (Press catch downwards to detatch suction jet pump)
11. Remove left sensor unit from the tank.
12. Reverse order to install
