Xbox 360 game Oblivion is saying "This save relies on content that is no longer present. Some objects may no longer be available. Continue Loading?" ...and when I say yes it freezes my whole xbox while loading. How do I fix this?
You have probably downloaded some DLC (DownLoadable Content) and it might have been deleted, so you have to re-download it to continue playing the game.
Either your savegame got deleted or corrupted. If it still shows up in the main menu, I would suggest copying it to a flash drive and trying to start a new game. If you can make a new game then your savegame is corrupt and you cannot use it anymore. If it will not allow you to make a new save then chances are your Fable 2 disk has been scratched and can no longer be used.
This is irritating but you have to wait a lot of game days until it pops up... for the profit make sure you have asked rumours around Anvil or another city. If you are in Anvil exit and come back in and he shall be in between Benirus Manor and The Chapel
Whatever save game you are trying to use requires some content or another that you downloaded from the web. You will have to go online and re-acquire the content for the game to load
The shivering isles isn't in anvil. First go to your map, scroll to bravil and look off to the right in the water. You should see a small piece of land that you can travel to, this is the door to shivering isles. I have this game, its amazing!
Make sure you delete the partially dl'd content (in the memory selection in the system menu). Also, clear the system cache by going to the memory menu. Select Y for device settings and then "clear cache."
In my experience, you have better luck downloading content OUT of the game you are downloading the DLC for. Go to marketplace, rather than go in the game and download.
i had the same problem u have to go on xbox live and it will upgrade your game, have disc 2 already loaded then sign into xbox live then play the game it will say upgrade for the game is required hit yes and thats it someone also told me if you get a game from sept 09 or later there is an upgrade for your 360 on the game i never tried it
Oblivion uses the Xbox 360 hard drive to cache game data and in some cases the info stored on the hard drive can get fragmented, slowing down the game's performance. Bethesda has already found out a way to fix the issue. Here is the official word:
Oblivion uses the Xbox 360 hard drive extensively to cache (copy and reuse) game data. This is done to optimize all loading the game does. It has been found in rare cases on some Xbox 360s that the cached data can get overly fragmented. This exhibits itself by the game taking a long time to load anything from menus, dialogue, sounds, objects, levels, and more.
To solve this problem, reset your Xbox, and hold down the A button as the game is booting up. If any button is held while Oblivion is loading, it will clear its hard drive cache, and create a new one.
Once you see the ?Bethesda Softworks? logo video, the game is already loaded, and the cache should have been cleared.
Note, this does not effect your game in any way other than loading. You will not lose any saved data.
