On the scan setting before you scan you can change the scan setting to pdf as a defauft setting press the current user and press start. hope this will solve your problem.
HH
SOURCE: Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
SOURCE: I have a sharp AR-M205 using sharpdesk 2.7 and can
When you installed the button manager you should be able to go in and change the SC descriptions ex. SC1, SC2 - SC6. When you use the sharp desk to scan you are operating in a pull scan but when you use the SC programs you are using the push scan mode. You can change the SC mode when you put the copier into scan mode.
SOURCE: I need to set a Canon IR 3025 so that the Scan
Hi fiona,
I am glad to help you.Press the "ADDITIONAL FUNCTIONS" button located to the right of the display. Select "communication settings". Now press "TX SETTINGS".Now press "common settings".Now press "Edit standard send settings". You will now see a screen that allows you to set the DPI value and file format.You will have drop down menus for each that allow you to change these settings. Once you have selected your preferred settings press the "OK" button located at the lower right. I have "FIXEDYA". :-) Rememeber, you can change these settings of a case per case basis on the main send srceen. Be well and smile when you get a chance.Please let "fixya" know I have helped. Thanx
