Kohler 18RESL  18 kW Emergency Power System  18RESL Logo
Posted on Jul 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My res12 indicates HE high engine temperature it is brand new 147 hours runs. best regards
Robert
Level 2:
Scholar:
  • Expert 97 Answers
  • Posted on Aug 30, 2010
Robert
Expert
Level 2:
Scholar:
Answers
97
Questions
0
Helped
45823
Points
189
New engines will run hotter then broke in ones do to tolerances are tighter more friction if it continues contact your warranty service dept before your warranty runs out
Temp guage not working 1999 alero
One advantage us dealer tech's have over a week end warrior is that we have factory service repair information and have factory scan tool ,Tech 2 , to check data coming into the instrument cluster . Most of you probably don't even think about how that coolant temp infor shows up on the gauge , except by a coolant sensor !
High Temperature Indicator
The high temperature Indicator function handles the control of the Engine Temperature Gauge Display and the red High Temperature indicator. The Powertrain Control Module (PCM) reads the Coolant Temperature Sensor, filters the messages, and sends the coolant temperature to the instrument cluster via a Class 2 serial data message. The PCM monitors the coolant sensor in order to determine a fault. The PCM transmits the Class 2 serial data coolant temperature report messages to the instrument cluster for the temperature gauge display and for the high temperature indicator control.
The instrument cluster receives the engine temperature data in the Class 2 serial data message from the PCM. The instrument cluster converts this data into a temperature gauge pointer position which drives the gauge pointer. The instrument cluster also uses this data in order to determine the high temperature indicator control.
The Body Control Module (BCM) looks for the high temperature indicator Class 2 serial data report from the instrument cluster and triggers a chime when the indicator is ON.
Your best bet , take it to a qualified repair shop , rather then just replacing parts .
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
High temp in freezer
Good Morning Friend,
I understand you are receiving high temperatures in the freezer of your Frigidaire refrigerator, model# FRS3R5EMB. I suggest lowering the temperature in the freezer portion of your appliance. Give it 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
7helpful
3answers
P0128 (and P0116) on 2006 GMC Sierra v-8, 5.3L, 4x4. Originally getting low temp readings on guage. After replacing the thermostat, the problem seemed to be fixed. A few days later, I was getting my...
P0116 - Engine Coolant Temperature (ECT) Circuit Range/Performance Problem
The ECT (Engine coolant temperature) sensor is a thermistor which changes resistance based on temperature of the coolant in contact with it. The ECT sensor will be located in the block or coolant passage. Usually it is a two wire sensor. One wire is a 5 Volt supply from the PCM (Powertrain Control Module) to the ECT. The other is a ground to the ECT.
As the temperature of the coolant changes the resistance on the signal wire changes accordingly. The PCM monitors the reading and determines coolant temperature in order to perform essential engine fuel management. When engine coolant is low, sensor resistance is high. The PCM will see a high signal voltage (low temperature). When coolant is warm, the sensor's resistance is low and the PCM will see a high temperature. The PCM expects to see slow resistance changes on the ECT signal circuit. If it sees a quick change in voltage that isn't consistent with an engine warming up, this P0116 code will set. Or if it sees a lack of change in ECT signal, this code may set.
Symptoms: There may be no noticeable symptoms if the problem is very intermittent, however the following may occur:
MIL (Malfunction Indicator Lamp) illumination
Poor drivability
Black smoke at tailpipe
Poor fuel economy
May not idle
May exhibit stalling or misfires
Causes: Potential causes of the P0116 code include:
Missing or stuck-open thermostat
Bad ECT sensor
Short or open on signal wire
Short or open on ground wire
Poor connections in wiring
Possible Solutions: If there are any other ECT sensor codes, diagnose them first.
Using a scan tool, check the ECT reading. On a cold engine, it should match the IAT reading or should be equal to ambient (outside) temperature reading. If it does match the IAT or ambient temp, check the freeze frame data on your scan tool (if equipped). The saved data should tell you what the ECT reading was when the fault occurred.
a) If the saved info indicates that the engine coolant reading was at the coldest exreme (around -30 deg. F) then that's a good indication the ECT resistance was intermittently high (unless you live in Anchorage!) Check for an open in the ECT sensor ground and signal circuits and repair as necessary. If they appear okay, warm the engine up while monitoring the ECT for any intermittent jumps high or low. If there are replace the ECT.
b) If the saved info indicates that the engine coolant reading was at the warmest exreme (around 250+ deg.F) then that's a good indication the ECT resistance was intermittently low. Check for a short to ground on the signal circuit and repair as necessary. If it appears okay, warm the engine up while monitoring the ECT for any intermittent jumps high or low. If there are replace the ECT.
Other ECT sensor and circuit related DTCs: P0115, P0117, P0118, P0119, P0125, P0128
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. Similar codes: P0125
In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolant temperature (ECT) sensor reading, and the speed of the vehicle.
Symptoms: You will likely not notice any drivability problems other than the MIL illumination.
Causes: A code P0128 may mean that one or more of the following has happened:
Low engine coolant level
Leaking or stuck open thermostat
Faulty cooling fan (running too much)
Faulty coolant temperature (ECT) sensor
Faulty intake air temperature (IAT) sensor
Possible Solutions: Past experience indicates that the most likely solution is to replace the thermostat. However here are some suggestions on troubleshooting and repairing a P0128 OBD-II code:
Verify coolant strength & level
Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
If the above items check out good, replace the thermostat
If Nissan vehicle, check for Technical Service Bulletins (TSBs), as the ECM may need to be reprogrammed to correct the P0128 code
These codes are telling you that the engine temperature is not sufficient. This can be caused by a faulty coolant sensor,air in the cooling system,or a faulty computer.
The engine should run at 190 F & higher when warmed up. Scan the computer system to view engine temperature.
Keep us updated.
1helpful
What should the compression be for a 1983 GS650GT, I have readings of 160 psi on three cylinders and 180 psi the other, I'm going to redo the check again with a different compression tester.
Taking compression test:- the bike's engine should be at normal running temperature and also tht the throttle should be in fully open position.
Your bike's engine has a compression ratio of 9:4:1
here is a guide frm compression ratio to psi :-
8>1 = 102.9 psi
8.5>1= 102.9 - 110.25 psi
9>1= 110.25 - 117.6 psi
9.5>1= 117.6 - 124.95 psi
10>1= 124.95 - 132.65 psi
10.5>1= 132.3 - 139.65 psi
11>1= 139.65 - 147 psi
11.5>1= 147 - 154.35 psi
12>1= 154.35 - 161.7 psi
Hope this helps!
3helpful
2answers
Temperature keeps dropping the then going back to
The system is perfect. That is how it works.
It is nothing to worry about as the Thermostat is functioning well enough.
Good luck and rate this solution.
1helpful
What type of oil to use when changing oil
For any four cycle engine (engines with separate oil and fuel fill locations) use high quality detergents in the following viscosity.
For Briggs & Stratton engines use an SAE30 oil above 40 degrees F (4 C) and below this temperature use 5W-30.
For Tecumseh engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30.
For Kohler L-Head engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30. For Kohler Overhead Valve engines use a 10W-30 above 0 degree F (-18 C), and below this temperature use a 5W-30.
For Honda engines,10W-30 is recommended for general use, and above 55 degrees F (10 C) you can use an SAE 30.
For MTD Brand engines, SAE 10W-30 is recommended for general, all-temperature use.
(From the MTD answer pages). Best regards, --W/D-- Please feel free to rate my solution. Thanx.
3helpful
1997 2.4L Chevy Cavalier LS; Low Coolant Indicator and Temp Gauge
take the cap off of the radiator (whil engine is cold) start and run the vehicle. keep runnig 30mins after the vehicle is hot keeping notice of the rad fluid level.
keeping the cap off will prevent the pressure build up that woiuld keep the air in the system, keep adding water or antifreeze as the level goes down. this may take an hour or so.
also with the cap off, you will be able to see if your water pump is operating correctly. you will visibly be able to see movement in the rad when the pum is engaged.
Carburator
Dear Sir,
Recently i brought a Toyota Tersel Car, its every things are ok but its fueal Consumtion is very bad, its 98 brand New miodel , running total KM is 103,000
Eng No is 2E-3148032.
PLEASE GIVE ME SOLUTION FOR IT, I AM expect 12 Km Per Ltr, its carbulator model. but engine condition is good,
your kind cooperation in this regard is highly appriciated
Thanks & Best regard
Saaranga
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
